15 Inch Rims -Want a bigger tire, What size tires fit?
SeaBass8
I just picked up a 2002 4Runner and it has 15 inch rims with 225/75/15 tires on it and they look tiny.
My question is whats the largest tire I can put on the 15 inch rims? The 15 inch rims are really nice so I was thinking about keeping the rims and put the biggest tire I can on them to make the truck look better.
I had a 98 Tacoma that had 15s with a weird tire size something like 31/10.5/15 or something like that, I can't remember now.
Pics of big tires on 15's would be great, thanks!
I'd bump up to 16's. Matter of fact, I think 17's are the standard now. Tire and braking options are better with larger wheels.
The width in more important than the diameter. And a 31/10.5/15 is not really a weird size, it's just not a metric measurement, it's a tire measured in inches is all.
knowing how wide the rim is dictates max tire size
These are 35x12.50r15. And a 31/10.50 is one of the most common tire sizes out there, nothing weird about it.
Lots of other questions... Lifted? Overall goal/use of rig? Backspacing of current rims? 33's, 35's, 37's all come in a 15" rim size.
Keep in mind the 15" wheel trucks also came with gearing appropriate for the tire size (3.73 or 3.90, I believe) which will make larger tire sizes worse for power/torque than the 16" wheel trucks.
Otherwise, the same overall size tires fit the same.
-Charlie
-Charlie
Good point! Best to look up the axle code and see what gears you've got so you know what you're getting into by putting on larger tires.
-Charlie
Beat me to it :)
If you put larger than what's on there, your speedometer will read you are going slower than you really are. Same with mileage. If you put say, a 32" or 33" tire on there, gearing will be a real issue and it will have absolutely no power down low. Most 15" 4Runners came with the 4-cylinder engine, so I'm assuming that's what you have as well. It'll be a real slug. However, you might be able to swap out the entire 3rd member from the rear differential and put in a 4.10 ratio 3rd member from another 4Runner, or at least a 3.90 from another 2WD 4Runner if you don't have 4WD.
It's got the 3.4 V6. It's all stock right now.
It's not lifted now but I will likely install a mild lift at some point. 2 inch spacer up front and a 1.5 spacer inch in back. That's what I did on my '97 and I like the stance.
Honestly I don't really do any off-roading so this is mostly for aesthetics. Likely I will be looking at a All Season type road tire that will ride nice but work decent in the snow as well.
I'm okay with losing some performance/gas mileage but not too much.
-Charlie
I'll see if I can figure out what gears I have.
The most common 15 inch size these days is 235/75r15. It seems in a lot of tire brands that is the only 15 inch option. The 225 size seems defunct now.
I have the 235s. They are visibly larger than the 225 I have on the spare.
Speaking of other issues, the 15" wheel trucks also have smaller brakes (smaller front rotors/calipers/pads and rear wheel cylinders). An upgrade to the 16" wheel components would be good idea if you go to a larger wheel with those larger tires.
-Charlie
