17 and 18" wheels with tires, Chicago AREA
terrytcl
SET#1 -
ENKEI RT6 Wheels 18" -
Wheels are 18x8.5 in size, center bore of 108mm, center caps included
Bolt size is 6 x 139.7 or 6 x 5.5.
Offset is 0mm.
Tires are Vogue Custom Built 285/60/18, tires were $175 each
tires have 8/32 of thread left
wheels have a couple small imperfections in the clearcoat, you need to up close to see them.
Paint nicks have been touched up using touch up paint. one wheel has a 3" light curbing.
Wheels were $800+ new
$275 firm
SET#2 -
GARA 17" Wheels
wheels are 17x8 in size, center bore of 108mm, center caps included
Offset if 0mm.
wheels have small nics from road debris, they can easily be touched up using touch up paint. no curbing. center cap key included.
These wheels have tires mounted on them.
The tires are 255/60/17 Dunlop SP5000 tires. they have about 40% life left.
Wheels were $550 new
$200 firm
SET #3 -
MB MOTORING Razor Wheels
18x8.5 wheels
Offset = +25mm
Bolt Pattern = 6 lugs 5.5 pattern (139.7mm)
Bore Size = 4.25 inches (108mm)
Silver / Clearcoated
EXCELLENT! condition
tires were mounted, but not used.
some very small surface scuffs on the edge from being in boxes.
no tires, but includes valve stems and center caps
These go for $640 new at Discount Tire.
$275 firm
TIRES -
General Ameritrac TR
Less than 2000 miles
They are almost NEW! Perfect for impending SNOW!
$82 each NEW at TireRack.
Manufacturer's Specifications -
Size -------------------------------- 255/70 SR17
Service Description --------------- 110S
Load Rating ------------------------ SL
UTQG ------------------------------- 500 A B
Max Load --------------------------- 2337 lbs.
Max Inflation Press. --------------- 44 psi
Tread Depth Tire ------------------ 14/32"
Weight ------------------------------ 39 lbs.
Rim Width Range ------------------ 6.5-8.5"
Meas. Rim Width ------------------- 7.5"
Sect. Width ------------------------- 10.2"
Overall Diam. ---------------------- 31.1"
Revs Per Mile ----------------------- 668
http://www.tirerack.com/tires/tires.jsp?ti...el=AmeriTrac+TR
$175 firm
GARAs
Enkeis
MB Motoring Wheels -
All wheels will fit:
Toyota 4 Runner 1986 - 2002
Toyota 4 Runner LTD. Sport 2003 -
Toyota Land Cruiser 1992 - 1997
Toyota Pickup 4WD 1986 - 1995
Toyota Sequoia 2000 -
Toyota T-100 1993 - 1998
Toyota Tacoma 4WD 1995 - 2000
Toyota Tacoma 4WD 2001 -
Toyota Tacoma Pre-Runner 1999 -
Toyota Tundra 2000 -
Complete set of lug nuts available
Must sell due to winter project.
Need to get these out of the house!
truckhigh said:
I was in terested in the enkei rt6. I was also wondering wjay the offset of the rims is.
i'm not able to find it on the rim anywhere.
i believe it's 0.
i have a set of wheels that are +25mm... and these are close to 0.
these might stick out a bit
bore size is 108mm
please email me
Can you please email me Dave at bigflange dot com regarding the Gara wheels?
I'm in Arlington Heights, BTW!
wheels and tires
hi
iam interested in the 18inch enkei wheels and tires will you ship i will pay for shipping
thnks island runner
how much would you charge me for just the rt6 rims no tires shipped to cali. I can paypal you the money ryt away!
