17x9 level 8 MK6
4RUN0326
Hey guys looking at doing these wheels as a cheap option instead of the Konig six shooter or countersteer type x's. I was wondering what backspacing to get with these. I understand that with a 0 offset that it still will push the wheel out because of the wheel width being 9inchs instead of 16x8's with 4inch backspacin which i have currently. I was curious if that i were to run 285/70/17 nittos on the 17x9 0 offset if I would still be running into issues with the tire running into the upper control arm. They also have an option of a 17x9 with a -12 offset but that just seems like it would push the wheel out much too far. A little help here? Also I would like to run the p metric 285/70/17, does any run these, do you think they are to light of a tire for an occasional trip to the rocks?
I have the same question. Did you ever find out if they fit? I know a 17x8 rim with 4.5 backspace would work, but like a lot more of the 17x9 rims. Putting the SS 1.2 lift on soon and want to upgrade tires/rims.
Why don't you just go with the 17x8 version they have? If you went with that your tires would still fit fine, and its a pretty common wheel to run.
2001ATL
