'19 TRD PRO Slight Lift Question w/ new Fox suspension options
HAMMER77
I have a Black TRDP on order and should be here in about a month. I'm thinking about a 2/1.5" lift level kit, but not sure if there are any that kits out there that will be compatible with the new Fox suspension. Does anyone know? Also planning on running 285 KO2's on SCS ray10's.
If the lift you are contemplating is compatible with a SR5, it should also be compatible with the Pro setup. Mounts should be identical. FWIW I would leave it stock for a bit as I have heard the Fox setup works really well. Good luck and congrats on the new ride! Post up some pics when you get her, we all like pics!
I'm think I just want to do a cornfed spacer lift like others have done on their PRO w/ the Bilstein setup. The Fox set up is different though and not sure if those spacers will work.
I am new to the 4Runner world, but the general consensus is spacers are a waste of time. I have no experience with them but it makes sense..
You have to remove the spring from the strut, why not at least install a lift spring? Dobinson has a taller spring with the same rating for around $200
Just something to think about.
What color did you order??????
I don't know how much homework you've done on this, but I'll offer a little from my experience. I just picked up my 2018 Cavalry Blue about 8 wks ago. Went with Cornfed 1.5" in the front and Wheelers T13 coil springs on the rear, which gave 1" of lift. The wheelers was supposed to increase the spring rate, which I wanted as I knew I would be loading it down some. As it sits right now, it's about 1/2" higher in the rear, but with even 100-150lbs in the rear, it sits level to nose high. That said, if I had it to do over, I would have done the same lift on front (1" spacer on front) and rear to keep approx 1" rake. Hope this helps.
Was that a private sale? Because the new fox suspension is a 2019 trd pro priviledge.
I work at a Toyota store and I think I saw a price in some corporate email about it being around $2700.
This has to be a pretty great suspension system and that's why I want to keep it and add spacers so I can fit 285's. I won't be doing much rock crawling since I live in the midwest and it'll be my daily driver.
Why would you buy a Pro if you plan on messing with the suspension? get an ORP and order an Icon stage 1 or two set up. buy the pro rims and bigger tires of your choice and sell the ORP rims on here or CL. you can install the suspension yourself or pay an org member in beer to do it. While you are installing the suspension, paint the front an rear valances so they dry while you work. TSO is a much cheaper alternative to the pro grill garninsh.
You will be in for less $ and you will have puddle lights and a sun roof... KDSS as well if you choose.
Do we have the compressed and extended length of this TRD Pro Fox shocks? Its hard to think of other lift options aside from spacers considering the mounts are the same with other models as mentioned earlier.
Or you can wait for suspension vendors to come up with a compatible lift kit for your TRD Pro Fox.
If I'm on the situation and budget is not an issue, I'll buy ahead a good aftermarket suspension that will give me the amount of lift I want. Take off and sell the fox when it arrives while they're still hot.
You buy a Pro for the color and for the 19's it's the JBL premium sound system that makes it worth it along with the color.
True, but this years voodoo looks like dodo, so tgat doesn't count.
And with the jbl you are still stuck with entune... after pandora gets dropped, is it even worth it?
My point is, uf you are particular about your vehicle and will mod it... the pro is not the best option. If you are not going to mod, the it is a good option.
Looks like doodoo !
Just curious
Would that 14" 600# front coils from fox or king work with the stock Fox TRDP shocks?
Just wanting another inch of lift and would rather go with the taller coils instead of spacers if it's compatible.
Any info on this is greatly appreciated!
tssawlson538
