1984 4runner RPM fluctuates then stalls
izzy434
I have a 1984 4runner. I tried using some carb cleaner, thinking that it would help the carb. But after I did that the engine started running at high RPM's and then it would jump to a higher rpm, then drop down, and eventually lower and then dies. I start it up again, it does the same thing. I cleaned out the egr valve, and changed the plugs. No difference. I don't find any vacuum leaks, and I don't know what else it could be. I wonder if I would do better to just remove all these crazy vacuum lines, and block up the openings. Not sure what direction to go. Any ideas?
Sounds to me like you have a jet issue. As if the low idle jet is clogged. It's been a while since I had monkeyed with carbs but I would start there as I'm sure your problem is there.
Take the jets out and run it through a ultra sonic cleaner. Sometimes a particulate can shoot through them so fast it can score the metal and mess up the spray too so may have to replace them.
How long sense a carb rebuild and tune?
^^^^I agree.
Carb rebuild or at least a good cleaning. Take apart and clean out the bowl. Could just be crap floating around in there
AndiGarage
