1987 4Runner "The Turd"
Champ1415
Picked this 1987 up last Saturday and started ripping it apart. Paid $2100 for her in Boulder, Colorado. 186k on the ticker.
Took her to get new wipers immediately after.
Last week I ripped out all the seats and carpet. Put the seats back in until I can find replacements.
Drove it to work and it was overheating so I changed the Oil, trans fluid and flushed the radiator. Also the rear u-joint and driveshaft where shot. Found a replacement and put it back in good as new.
Realized the tires where different size front to rear so I found a good deal on some new tires and rims from a 5th gen.
As she sits as I write this new build. Trying to get better at documenting all the projects.
Picked this 1987 ...
Good price if in good running condition. I paid $2700 for mine- but she's a stick shift.
Looks like the rear sag has been fixed. Stock Springs? Zuk? or blocks?
Just stock springs that I know of. Front is about 2in lower. SaS and a 4.7
I hated this color when I first got it but it grew on me and now I miss my old runner :(
Looking forward to seeing updates!
sTJcfNfMrr-NiCgjJVTbDy-yCbVz4T2PErwzbe7qlV84X6C9QRMY5SvUj6BGh7Buf6NtazPj6bgrWLlo0qMBSEAMay10CTLGPUBoR6ZkBgBupcljoF8YDzA11VBDEUeXKVUwPAToPFOJyV7yUgSysqbBJF5LpC4D20pnTASZ427ElZ-wpq1L0tUOg-GEZSCOycTqldIo__uweyZb3lNdfihJg_CkqvQ7c99H_j_n5c96m2ADyI8gteIOQpaucm4TFck7XAop7wzU7v6muqx4lcrcukafTRfAbEyBdh6j4t1UDU9Wlu7BFZGjkF-NmuiUq8k5qckzBxZDTK-a3GsSCA_j8mSapB49rPbW2hg9Z2cctiJDR8SKuwax01q3hgpRus0AQl-2tgWznVWSkju7q9zIcMX44D8gxQgfJtgXwLin6ptdS3TXMyR6eyEhYGr8Z0C5fTgdsbY6SFDu9XucNiin15bkJvJzEIdGXZnenMjNOmFhNmNuPQSL37Uaok6WHi5ZFldyfLp8WLEJHGNOHFRjolCIvQnigu8uoju6JwJVaNC-89H_XCMAJgVygPoAyJaG0b5QIQGqrfZtiTbUzX2fZz0Jm7E=w1187-h886-no
You cant complain about a 1st gen IFS for under 3 grand with that sort of body, and running no problem. Fixed the overheating? Golden.
I believe I have fixed it. My engine temp gauge isn't working correctly I've taken it out and checked it. No loose copper wire. I guess next stop it the sending unit. Also tackling the shifter. O/d is busted. Anyone have any diagrams for an automatic shifter with O/d
Did you have problems with the center bore on the rear axle? My center bore is roughly 4 1/16" and same on the drums doesnt sit right on the back..i also have 5th gen rims
Sent from my LG-D801 using Tapatalk
Previous owner destroyed the u joint. The yolk opening was Oblong
sorry i wasnt clear...i meant did you have problems mounting the 5th gen rims on the rear axle because of the hub/lip on the brake drums interfering with the center bore on the rims
Sorry I misread that. No I didn't have any issues. Mounted right up.
AndiGarage
