1988 LN61 4Runner RHD 2L-T 2.4L Turbo Diesel
npl420
SR5, A/C, Power Locks and Windows
The title of this post gives the skinny.
I purchased this diesel from a Japanese importer in L.A. in May 2014.
It had 182,000km on the odometer.
It's close to 188,000km now.
So far so good. I've been scouring the junk yards and replacing the cosmetics here and there as I find nice parts. It's been a fun project so far.
Engine seems to be running very strong. No leaks, tiny surface rust on the body. 30+ MPG.
Before I picked her up the mechanic gave her a thorough run down to make sure she was not going to give me any problems on the way home:
- Timing Belt
- Crankshaft Seal
- Water Pump
- Valve Cover Gasket
- Fan Belt AC Compressor
- Fan Belt Power Steering
- Fan Belt Alternator
- Voltage Regualtor
- Alternator rebuild
- Fuel Pump Assembly Rebuild
- Double Battery Bank
- Coolant service
- oil change
In terms of my additions so far:
- Upgraded to Rancho Shocks x4
- New 4x Innovations rear bumper
- Wheel alignment
- New set of tires
- Dual Roof Rack (One for removable Cap, one for truck cab)
Over the next three weeks I plan to get a little deeper with maintenance as I'm going to pack her up soon and drive from Oakland, CA back to the promised land of Vermont. I can't wait to have this girl in the East. I think she'll do the drive just fine.
Plans are:
Oil Change
Rear and Front Differential Change
Transmission Oil Change
Fuel Filter
If anyone can point me to specific threads which address these fluid changes - that would be most excellent.
I think the undercarriage stuff is probably relevant to most other 1st gen's. Diesel oil change will be slightly different with regards to capacity, etc. Fuel filter too.
Hope to connect with like trucked people.
Welcome to T4R, sweeeet truck.
If you search a little you can find answers to a lot of your questions.
I picked up the 4runner from a tire rotation and wheel alignment. All normal. After sitting in my driveway for most of the day, I went out to idle her for about 10min to get the engine warm in order to perform an oil change. I went back inside after starting, when I went back out, I noticed a lot of coolant on the ground and the overflow tank was bubbling/boiling. I turned the car off. I went ahead with an oil change. I didn't see any coolant in the oil, vice versa. After the oil change I started the car and a lot of white smoke or steam came out the pipe. I let it idle for a little while longer to see if the temp. gauge would rise, it was normal. After a few minutes the tail pipe went back to normal and no more white smoke. No heat was coming out of the vents when placed on High Heat. Lot's of pressure was building under the radiator cap.
This morning I replaced the thermostat and this seemed to fix the problem. Heater started working immediately. No more boiling over in the expansion tank. While I did lose quite a bit of coolant throughout my diagnosis cycles, I was repeatedly filling it back up directly in the radiator cap. I was also keeping the expansion tank topped off. Since allowing the engine to cool down after the replacement, most of the coolant within the expansion tank has been sucked backed into the engine. This is a good sign. Do you think I should refill the expansion tank back to the full line with distilled water or more coolant?
I couldn't get the exact OEM thermostat because the autoparts store could not cross-reference to the 2L-T diesel, only the gas version. The thermostat I used looks somewhat different, same diameter size and gasket, same temperature setting 88degC, but different length and missing a spring unit on the bottom. I plan on ordering the OEM today and using the truck for the next week as is. Question is, beyond just filling the coolant back to normal, do you think I can roll like this until the new OEM thermostat arrives? This is the part:
(90916-03099 - Genuine Toyota THERMOSTAT)
The temporary replacement is:
http://www.amazon.com/Motorad-240-192-Thermostat/dp/B000C5I82U
When I do get the OEM and install it, do I need to do a full coolant flush/refill?
Thanks for your thoughts!
- nick
Philthyphilthy
