1990 T4R battery not keeping a charge
drkowatch91
This is the first time I've used this forum so bear with me. So my 4-Runner's battery is dead. But the battery is new. I have an old and new alternator, both do nothing. I have to get them tested to see if either still work. so my question is thus, should i be looking for a loose wire or something small like that, or do I have a larger overall problem with the electrical system of the car? I am inept when it comes to cars, so I was just looking for advice or past history with similar issues. If you care to interjected your two cents I am all ears.
I'm on my phone so I can't link you, but search out user name "Rad4Runner" and his build/mod thread. He's got a layout of the charging system in there that will help you chase down any wiring troubles. With a brand new battery and two different alternators giving you trouble, I'd say a wiring issue is a distinct possibility.
If you dropped in a new battery, how long would the charge last? Few hours? Over night?
Any other systems in the truck that could be staying on? Amplifiers, remote starters, security systems etc...?
Welcome to the forum!
No charge error light?
Battery connector and post clean all the way to bare metal? Gun-metal/gray is not bare metal in electrical terms. Bare metal is silver or copper, depending on connector material.
With engine running
Measure voltage at battery post - yes the lead post itself.
Measure voltage at alternator "B" post. There should be very little difference if any
...should i be looking for a loose wire or something small like that...
Absolutely.
or do I have a larger overall problem with the electrical system of the car...
Hope not. Hoping it's just a loose wire/poor connection somewhere.
Something could be wrong with the wiring. Sometimes, people suspect the alternator and replace it, without verifying that it's really what's causing the problem. With new alternator, system still does not work (of course). Then people say that that re-manufactured alternator is also bad. A brand-new premium alternator with gold wire for windings and titanium housing would not fix the problem, because the really defective part of the system (the wires) are still there.
Do a thorough check/voltage checks of the charging system first. IT will not cost you a dime, and may even save you from buying another alternator that will not solve the problem, after all.
This 22RE charging system should be close to your truck's.
Also, if your system has this...Also Open and inspect it.
95417291-cf16-4e1a-9936-7f4d622583e3_zpsf8501af4.jpg~original
This looks like a ferrite choke but it is not.
(We're not choking ferrets -Who's line was that BTW? LOL!)
This is the equivalent of the appendix in human terms. I am not aware of any 4Runner owner on T4R.org or Yotatech who had put this to any use in the past 30 years.
If there is poor connection here, your regulator will see good output from alternator, so you will not get the "Charge" error light. So you would think your charging system is working properly. However, the truth is that alternator output is never reaching your battery.
001_Just_Junction_Point_zpsa274310f.jpg~original
Take it apart, clean everything thoroughly down to shiny bare metal, re-assemble. Better yet, replace the whole battery to alternator wire with one continuous piece of thicker brand-new wire, and scrap this useless part.
This may sound silly but do you have a stock or aftermarket radio?
I had the same problem, and it turned out I had wired the radio slightly wrong and the rear speaker amps were draining my battery.
BillM777
