1992 T4R 3.0 Clutch questions
FubarGrn
Alrighty, I'm pretty knowlegable when it comes to my T4R, but I can't remember this one to save my life and my FSM's don't have the info.
Is there an "adjustment" to the release cylinder rod? I'm replacing it in a few hours, and I'd really like it if I could tighten this thing up to where there is almost no free play at all (I like my clutch pedal REALLY tight). does the rod just screw out as the "adjustment"? If so, are there any detrimental effects to having so little free play in it (i.e: making the clutch wear out faster)?
Also, When bleeding this, I've seen several methods, and I'd like to know wich is the fastest/easiest/less stressful. Should I bleed it like brakes? Gravity bleed it?
