1995 4runner rear sag.
sadiq
Hey guys.
This is my first post and I'm guessing this question has probaly been asked a bunch of times but I couldn't find anything on it by searching the forum so here it goes; I have a 1995 4runner(2nd gen.) 4x4 bone stock and the rear of the car sags sooo much it's not only only cosmetic issue but i'm guessing it could be a saftey concern while towing or off roading. I'm guessing the rear coils are bad, I really don't wanna get the stock coils since they too will also wear out. Is there an aftermarket set of coils that could make the height of the rear level w/ the front? Also how much would the coils and labor to install them cost? Thanks a lot for your help!
Sadiq
This is a typical problem with 4runners. Go to Downeyoff-road.com and you can order 1.5" lift coil springs for the rear with an easy install. If you choose the "heavy duty" springs, you won't have to worry about them wearing out any time soon. You can also install spacers for the rear from companies such as cornfedsuspension.com. Hope this helps.
Hey thanks for the help. Yeah I ordered the 1.5" inch heavy duty rear coils from Downey, they should be in a couple of days. Can't wait, I'll see how the car sits after the coils and then if I still need some lift I'll get the spacers. Anyhow thanks alot for the help.
Sadiq
Deelock
