Southern_Momma
I am really trying to figure this out with your help rather than get :bash: at a local shop.
I bought a 96 4 runner with 280K miles on it with a check engine code, hard to handle steering wheel, and def something going on with the alignment/frame/shocks or lack thereof. It has an after market exhaust system. Anyway, it at least would crank up with some hella power and run fine so I wasn't too worried. Drove it all around for a couple of days, then I filled the gas tank up and had the oil changed.
Went to crank the truck up after I left the oil place and ran to the store and it has given me the same problem ever since... it tried to turn over but then "shuttered" and didn't fully crank up. for about 10 mins. Reeeeally long story somewhat shorter, the code that has pulled back is P0171. If I only run the truck up the road, it will crank up fine. If I run it any amount of time it is like something inside is warm and won't crank up for anywhere from 10-60 mins... depending on how long I drove it. If I try and try to turn it over it ranges from what seems like a little skip to a full on shutter to a popping with a shutter to the smell of horrible bad gas. I need to add that this has been going on for a couple months.. and I have tried getting gas at 7 different locations. It def does NOT have the same power as it did the first couple of days. One thing that a stranger showed me was to take the exhaust off and put a "shot" of gas from a bottle in it and crank and that works like 7 out of 10 times on the first try. What the hell does that mean?
WHERE DO I START? Tell me what to replace or clean or check first and I will go down the list. With all the videos out there I should be able to just about anything myself and with the right tools. Said the woman with a messed up truck... Thanks guys n gals!
