1998 with 3rd member howl and movement
So I called my favorite local parts house to get a 3rd member rebuild kit and he is telling me that I have a choice of 2 pinion or 4 pinion. The only thing that makes sense to me about that is 2 spider gears or 4 spider gears. Anybody run into this before? Thanks, Brian
Either one of those quotes beats the $2000 quote I got from the dealership...because they don't rebuild them. Thats for a new one, and without labor. Good to know they're available though...just in case.:lol:
That's garbage, Retail is about $1500, and toyota of Dallas sells it the whole shebang for $1k. Man dealers suck.
OK, have 4 spider gears. Does that mean it is the 4 pinion unit? I will admit that I am in over my head on the technicalities, I am taking the 3rd member untouched to a qualified indiviual to pull apart and set back up. I am just attempting with my meager knowledge to gather the proper parts first :-) Thanks, Brian
Just be sure you are using the same terminology as in the link. There are pinion gears, and side gears. If you have 4 gears in the carrier (2 small pinion/spider gears and 2 side gears with internal splines), then you have 2-pinion. There wasn't a good pic of the 4 pinion, but with 4-pinion you would have 6 gears in the carrier (4 small pinion gears, and 2 side gears with internal splines) and a cross shaped piece in the middle. I think you should have 4-pinion.
I'm having the same issues you are describing with my 99 runner. I found this site while looking for a used 3rd member. Has anyone ever looked into these folks? Curious if it's a reputable source and could be a turn key deal for a rebuild rear diff.
JawsGear.com
Peter
