1999 4Runner - SR5/4wd/3.4L
S2kstephen
Toyota 4Runner - SR5
167,000 original miles
Clean title
4wd (non e-locker or TC)
Black/Beige combo
16/20mpg
SOLD
This was originally purchased in NY, but has been spared from being rusted out. Clean and solid frame, but light rust from year around usage. (pics attached). Front & rear bumpers, roof rack, rear spoiler, license plate garnish, and front grill have all been Plastidipped (chrome is ugly, imo).
This has been very well maintained; timing belt/WP, etc done at 95k and regular maintenance by the 3 previous owners. Runs fantastic, fires up smoothly, and rides like a dream at 70mph. Everything works, nothing leaks, all buttoned up.
I completed all the new 'T4R new owner' maintenance in the last 500 miles.
New brakes F&R
New spark plugs & wires
New headgaskets
New air filter, clean MAF/TB
Seafoam treatment
New PCV valve
OEM Radiator
All fresh fluids: engine oil, F&R diffs, coolant, brake.
BRAND NEW in the last 100miles:
AVS ventshades
20% tint all around
New Energy Suspension sway bar bushings, F&R
New HD sway bar links, F&R
New Energy Suspension steering rack bushings
New LBJ's (OEM Toyota)
LED's throughout (cluster, dash, center console, roof, reverse, license plate, everything)
Clear signal lenses with LED's
Clear turn signals with LED's
BX Built projector headlights with BX Built LED bulbs
Level-8 MK6 17x8 -10 wheels
Custom TRD center caps
Nitto Ridge Grapplers 265/70/17 tires
Muteki lug nuts + locking lugs
Ultragauge - for monitoring vitals
Stereo: Boss head unit, Alpine 1000W sub, 2 Kenwood 12" subs. All wired professionally.
Cons:
The exterior shows it age; the drives front fender has paint fade, there is a small area repaired from rust by the passenger rear fender well, and the exterior shows usage from daily driving and use. Not previously been used as a off road vehicle.
Drivers OEM floor mat shows heal wear
Suspension is original - but perfect for your choice of lift or shock setup
The steering wheel shows wear, and on rare occasion makes a very light squeaking sound during rotation
*Glad to provide any pictures, Facetime with you, text/call, etc.
Interior pics:
Underside & wheel/tire package:
*Pics do not reflect upgraded sway bar links/bushings/etc.
Price drop - $13,500
Can sell with OEM wheels/tires and factory headlights for less.
Are you sure that's a 2002? 2001-2002 transfer cases have a different shift pattern and a center diff locker, and the grille on the one in the photos is from a 99-00.
EDIT: I also see a transmission throttle cable in this photo: https://www.toyota-4runner.org/3678387-post7.html 2000 was the last year for this cable.
Upon further investigation, it does appear the vehicle is indeed a 1999. There was a clerical error on the title that showed it as a 2002. Thank you [MENTION=319302]Bad Luck[/MENTION] for helping me discover that.
DJNutshell
