1999 Supercharged 4Runner Auto 4wd forsale
terrytcl
1999 Toyota 4Runner SR5
SILVER EXTERIOR / BLUISH GREY CLOTH INTERIOR
The 4Runner has 127k miles, but engine and transmission are running 100%. Recent tune up has been performed.
The 4Runner is 4x4 and has an automatic transmission.
Options: Air Conditioning, Rear Air, Power Steering, Power Windows, Power Rear Window, Power Door Locks, Tilt Steering Wheel, Cruise Control, AM/FM Stereo with Single Compact Disc, Dual Front Air Bags, ABS (4-Wheel), Moon Roof, Roof Rack with Thule Rack (factory rack included), Rear Windows Tinted Glass, Running Boards, Towing Pkg with Stainless Steel Drop, Chrome Ball, and Adapter Lock,
TRD Supercharger Package, TRD Transmission Oil Cooler, Flex-a-Fan electric dual fan kit, Carbon Fiber Simulated dash kit, Addco front and rear sway bars, Energy Suspension Greaseable Front Polyurethane mount, Energy Suspension Greaseable Rear Polyurethane mount, Airaid cold intake kit with box, Billet Aluminum Oil Catch Can, Denso Irridum colder plugs, 2002 Toyota front skid plate, Cross-drilled front rotors, Stainless Steel braided brake lines, 18x8.5" Akuza Wheels, BRAND NEW - 265/60/18 BFGoodrich Radial Long Trail tires, Clear bumper lights, Clear corner lights, Aftermarket driving lights (wiring installed, lights not mounted yet), NGk Spark Plug Wires, Window Smoked Visor Kit, Lunk Smoked Hood Visor, SpeedBleeder Bleed valves (all 4 wheels), Pioneer CD Deck with Steering Wheel Mounted Control
Maintenance items completed -
Amsoil Transfer Case Fluid
Amsoil Front Differntial Case Fluid
Amsoil Rear Differntial Case Fluid
Amsoil Transmission Fluid
Brake Fluid Flushed and Refilled with Castrol Synthetic Fluid
Coolant Flushed and Refilled (added Redline additive)
New Fuel Filter
New Rear Wiper Assembly
New Power Antenna Assembly
New Rear Axle Seals
New Front and Rear Brake Pads
New Rear Drum
There is one small door ding on the rear driver side door, the rear chrome bumper has some dents in it from the previous owner. These are all cosmetic.
Everything else is mint.
$9500, which is under Blue Book.
I will throw in a 15.5' Pelican Canoe with 3 paddles and a motor mount. Also mounting pads and tie downs. A $700 value for free!
If you buy before the end of this month, I'll also throw in the following items -
1) LEVEL 10 Torque Converter
2) Supra 2JZ-GTE MAF
3) Supra 2JZ-GE Injectors
4) 9 PSI Billet Aluminum Supercharger Pulley
5) Hollowed out Factory Cat
= $1000 worth of goodies
bad picture
more coming
http://im1.shutterfly.com/procserv/47b5cf35b3127cce951f2a4721fa00000016103AZtWzlwzYu
