1st Gen (Gray) TRD Supercharger, Capitola CA, $1900
SCRunner12
I have a completely rebuilt 1st Gen gray TRD Supercharger for sale. I replaced all of the bearings and seals (nose cone bearings and seal, rear needle bearings and coupler). The rotors, rotor seals and rotor plate are brand new. I have also tapped the nose cone and added a fill/drain port to the top of the nose cone to allow easy fluid changes. It will come with your choice of the auto trans or manual/drive by wire throttle bracket. Also comes with the dymanic tensioner, install parts (3 long bolts, new belt, new throttle gasket, 2 steps colder spark plugs). Only thing missing is the IAC check valve that has been discontinued by Toyota.
Located in Capitola, CA and $1900 shipped obo
Since I will get questions, I did have this SC for sale a while back. I sold it to santacruzrunner and he ended up putting it on 30 miles from home and drove home after the install. Turns out the tolerances weren't quite right and the rotors were contacting the housing. I had a replacement housing and new rear needle bearings were installed. Also I bought a brand new rotor assembly already assembled (rotors, bearings, seals and plate) and used that for this rebuild. In an abundance of caution the front nose cone bearings were replaced again. All moving parts are brand new and perfect working condition. This is essentially a completely new unit and has been tested for two weeks on my 4runner prior to removal. If anyone would like a video please send me your number and I will text it to you. I wanted to be completely up front about it prior to sale.
tobasko556
