1st Gen: Rear wiper not working
totheriver5
Couldn't find my particular problem so thought I would post.
Rear wiper doesn't work. Rear window works fine. I put it up and down everyday and did modify it so I can operate from the center console without the key in the ignition. My defroster works (light goes on at least) and when it's on and I lower the window the light goes off, so I think the limit switch works. I pulled the switch out of the center console and it seems to work fine (no continuity when off, then have continuity when press it on). No blown fuses or at least I can't find any fuses for the rear wiper, window, and everything else seems to work
Here is one problem: When I check the leads of the for the plug for the switch under the center console I can't find any leads with power.
any thoughts?
delislerebecca
