Windshield Washer help please
five-alive
Junior Member
All the sudden neither my front or rear washers are spraying. Here's whats happening:
-Wiper comes on when I pull the washer lever.
-No pump noise when I activate front or rear washer
-washer pump shares fuse with wiper motor correct? so if the wiper works not a fuse problem?
I guess it is possible that both pumps crapped out at the same time but not sure how probable. Anything else to check?
check the pump itself, apply power directly to the pump and verify if the pump is working. maybe its jammed or you have a frayed wire.
jesslstn854
