1st Gen T4R Picture Gallery
Looks good! 32s Should fit, but youll have to trim a bit. The 31s will fit with no trimming.
Welcome to the forum!
Took delivery of the Surf. Cleaned it up and replaced a couple of non standard and missing items...gearknob, ashtray.Dealer put back the original steering wheel. Gonna be in temporary storage till i get a softtopper for it :)
First Post! I've been poking around for awhile trying to pick up tips here and there and I finally picked up an '89 3.0 5-speed last night. I really wanted an auto but I couldn't pass up the price I got this one for.
She needs some work, some of which I know about, and some that i am sure to find. Plans are to get her stripped down on the inside so I can get in and take a good look, then start the list. Not gonna try to make her pretty, just want something to teach the boys how to "wrench" and take on some camping trips.
Congrats on the purchase! The 5 speed is the only tranny you want behind the 3.0 IMO. And welcome to the forum!.
:welcome:
:welcome:
psh i love my auto. once i regear it will be even better lol
with an auto, you get a lower geared t-case so in 4 low you crawl slower than any stock 5 speed. this saves me from having to get 4.7 or dual case
Thats actually a good point, the auto does help you crawl, but not because of the gearing, The transmissions 1st gear is higher than the MT, but the t-case on the auto is a little lower, not much though.
Good info here: http://www.4x4wire.com/toyota/faq/parts/
Also, you cant do 4.7s or dual cases with the a340h, like you can with the 4cyl auto tranny.
Thats actually a good point....but you cant do 4.7s or dual cases with the a340f, you can though with the 4cyl auto tranny.
I plan on running the 5-speed for as long as I can. Once it gets to a point that it needs a rebuild or replace, I'll hopefully have some time with it to decide which way to go.
Anyone else have a 1st gen with 2 door handles inside on the passenger side that both work?
<a href=http://s226.photobucket.com/albums/dd5/theonetheonlybigred/?action=view&current=IMAG0152.jpg target=_blank><img src=http://i226.photobucket.com/albums/dd5/theonetheonlybigred/IMAG0152.jpg border=0 alt=></a>
Both of my passenger side door handles work. What I find interesting is that your 88 has a wing window.
just remove the panel and see if the plastic clips on each end of the rod are broken. common issue. most likely the plastic clip at the handle is/are broken. you can just buy the clip. pretty cheap and easy repair
ghengiskhan
