1st Gen T4R Picture Gallery
Old picture from July. East side Sierra above Lundy canyon
just some pics of my truck
hey guys just wanted to throw up a couple pics of my truck before and after this past summer. Ive had it since the beginning of last summer. The previous owner took great care of it. Tell me what yall think of it
The motor was put together by me because I'm a mechanic. Saved me $2000 and change for me to put it together. Looks stock, but sounds/performs nutts.
ALL STAGE 5 SERIES ENGINES COME WITH THE FOLLOWING COMPONENTS:
LCE Pro Stroker Crankshaft & Crankshaft Scraper
LCE Chromoly H-Beam Connecting Rods
Oil Pan
LCE Pro Block Brace
Clevite Main, Rod & Thrust Bearings
Brand New Water Pump
LCE Pro Oil Pump & Oil Pump Bypass (Pressure Adjustment)
LCE Dual Row Timing Chain Kit & New Custom Timing ChainCover
ARP Head Studs & ARP Main Cap Studs
Radically Ported Cylinder Head (Brand New Casting) & MLS Head Gasket
New OEM Aluminium Toyota Rocker Arms & LCE Pro Rocker Shafts
LCE Dual Row Adjustable Cam Gear
LCE Dual Valve Springs & Titanium Valve Spring Retainers
NGK Spark Plugs
Billet Oil Cap
LCE Pro Water Block Plate Kit
LCE "Red Head" Race Valve Cover
94mm Forged Pistons (Your Choice of Compression Ratios)
48mm Stainless Steel Swirl Polished Intake Valves & 40mm Stainless Steel Swirl Polished Exhaust Valves
Your Choice of Custom Performance Camshafts
Ambrose67
