BrianSD_42
I probably won't buy anything until Pres Day weekend. Hoping for that sale.
Hey guys, what King front coil weight are you guys using with this 2.5 setup?
Any advice looking back at the purchase? I've got that Tax return coming.
[MENTION=14772]shootmymime[/MENTION]
[MENTION=106117]99blackt4rsport[/MENTION]
[MENTION=82154]GSPRunner[/MENTION]
[MENTION=82211]TCMach[/MENTION]
[MENTION=95069]TBuzz[/MENTION]
Thanks. If I go this route it will probably be the standard 650 option.
Great advice guys. Thanks.
Any idea who is going to have the best price, perhaps an upcoming Presidents day sale?
[MENTION=65101]BrianSD_42[/MENTION]
Oddly enough, upon closer inspection although my order read,
KING OEM Performance Series (25001-333EXT)
1996 - 2002 Toyota 4Runner
2.5 Front Coilovers IFP
Extended Travel for use with UCA
My box says 151 (EXT).
Did you go with the extended travel Kings? From what I hear, they are all the same, however, their is a little removable buffer in the non extended versions that can be removed to make it extended travel. We are not really talking about a lot of extra travel anyway, but there you go. I am somewhat curious as to why they sent me 600# coils on mine. I said 650# but told them what I had as far as weight goes and said if they thought I needed 700# given additional weight of skids, winch, front AOR bumper, then go for it. But 600# is what I ended up with. The ride is very nice by my estimations. If I need to, I can jump up to heavier springs down the road.
I did not get extended travel. Not sure how much extra that gives. Seems good so far.
They give about 1" additional travel. Same thing happened to my brother ordering his icon on 4th gen. Metaltech said go with the 600s.
This makes me wonder if the 333, or 333EXT is the same as the 151s...
Hard to say. I think I might reach out to King for verification. If you go onto TAP's Web site, and put in your vehicle, it gives you options for your 4runner. But it looks different than how it did just a few months ago when I ordered mine. I will check and see if I still have the tags that came on my coilovers. Maybe there is some information that I missed on those things.
So I went to King's website and here is what I am seeing....mind you the last time I talked to them they told me there is no extended travel for the 4Runner, and according to whoever I spoke to on the phone, said the tophat on the coilover is different from the 4Runner to the Tacoma. I know it sounds stupid, especially after seeing the boxes that says 4Runner AND Tacoma. Maybe the person I talked to was an idiot? So heres the data straight from their site.
I separated it all by the / because it was too wide the way it copies off the website.
Part#/Description/Type/Details/Weight Lbs/Compressed length/Extended length
25001-151/Tacoma 96-04 (6 Lug)/Front Coil Overs/48/15.325/19.5
25001-333/4Runner 1996-2002/Front Coilover/Internal Floating Piston/48/15.342/19.330
So what I have taken from this is the 4Runner coil has an internal floating piston, and has .170 inches less extension? I don't see any EXT versions on their site.
When I rebuilt mine this summer I wanted to jump up to extended. Well. As I tore things apart the internals looked nothing like what people had said. "Remove the 1/2" metal spacer and that's extended". I had no metal spacer.
What I did have was a large metal washer and rubber bump stop to dampen the rebound of the piston from smacking the seal head.
I talked to down south and they said you can remove the rubber bump stop, I called king and they said don't remove it. So I trimmed it down from 1/2" thick to 1/4". Yeah. I know a lot of improvement gains there. But oh well.
BUT. The real gains was on installation. I noticed that at full droop my spindle will not contact my spring. That's common on extended travel. As the suspension drops the upper ball joint / spindle moves closer towards the shock as it lowers. With more slack in the shock length the spindle can contact the spring. Well lucky for me I'm 1/8"-1/4" away from my spring.
I also rebuilt some icons last week. I was able to measure the usable shaft length. As lower mount is fully extended. And the length was about 5.5". (Standard length mind you) Where as my kings are about 4.5" stroke. So if I had icons I may need limit straps.
Food for thought.
Food for thought.
What UCAs are you running? And you were hitting the spindle before you trimmed the bushing and now you're not?
