1st oil change on the runner- got a question
General Lee
I do all my own oil changes, but this is my first on a 4runner. I crawled underneath and found a small oval plastic plate which I thought was to gain access the the oil pan. I rmoved the plate as it just snaps in and saw the smallest oil pan I have ever seen.
My question is what I saw... is that the oil pan? I thought I read on here about some changing oil from the top but I never had heard of that before. Do you have to remove that small oval plate to gain access to the oil pan. Thanks for any help.
From what I understand, the oil drain plug access is behind that oval plastic cover in the skidplate. I haven't done the oil change yet either, as the last two oil changes I've had were done by the dealership. But I will be doing it within the next couple weeks, after I pick up another couple thousand miles and then switch to synthetic. So I believe that is where it is, but I'd also like some confirmation.
Yep, on the V6 the crankcase drain plug is reached by popping off the oval plastic bit. The only thing up top is the oil filter...
General Lee said:
Ok, thanks.. So the runners have an overly small oil pan? Just want to make sure that is what I was looking at.
It's not that it's a "small oil pan", it's actually an extension to insure the oil collects in one spot for easy/complete draining (compared to a flat sqaure pan). I think it's a smart design.
I don't know about the V6's, but my V8 holds ~7 quarts of oil!!
