2.5" lift
Txjcb5002
Im doing a 2.5 front and rear lift. Looking at 285/70r17 Nitto. Will these fit with the 2.5 on stock rims? I don't see allot of 2.5' info. I would like to keep the mud flaps and steps and don't want to do the body mount chop either.
Please advise. Also I can not seam to find the XREAS disconnect and reconnect thread (keeping the XREAS )
I can tell you this, I put 285/75R17 Nittro Trails on my 4runner and I have 3", Had to remove my mudflaps, and do some major trimming to the fender liner and about an inch off the corner of the front bumper...and even still they occasionally slightly rub at full lock on bumps. As far as the back, you should be fine though. So I'd say you'll be cutting it pretty close, but you definitely won't have any problem rubbing the UCA or body mount, although you will need a set of spacers...I have 1.25" spidertraxx on mine.
Also...waiting on my shrockworks front bumper to come in by the end of this month, so I had no reservations about hacking away at that plastic haha
You'll need to loose the mud flaps, add wheel spacers, and do a good bit of cutting, sounds like you should stick with 265/70/17.
Jhunt
