2.7 (3RZ-FE) sound of worn timing chain?
Hi All
So after a full rebuild on my 3RZ-FE, I just drove 23,212 kilometres across Russia, without any real issues. However, there has been a creeping increase in fuel consumption. This might be due to the cold (30º C when leaving, -20º C close to the end of the trip).
But for sure, I have some minor engine symptoms. Firstly, the idle has steadily become a bit lumpy. I wouldn't describe it as rough, and there is no change in idle speed, but I can feel it hiccup a little when idling. The frequency of these hiccups is getting higher. At 2000 rpm or above, I can feel the engine is louder and rougher than it used to be.
Now, I suspect that swapping plugs and injectors (I have a new OEM set of both) will remedy the problem, but in case it doesn't and this is something more serious, can anyone describe the noise of a worn (i.e. stretched) timing chain in this engine?
EO
I apologize for having no insight into your engine issues, but I just checked out your website and I am excited to see what you guys have going on. Cool stuff.
Timing chains should last over 250kmi. What you described sounds more like a missfire.
Yes, I agree. I don't know the precise mileage of my vehicle as it started recording in kilometres in Japan, then had a chip to convert kilometres to miles, and I have now de-chipped it back to km. Probably about 150k miles at the most.
I think its a faulty injector which is building up to a miss. Just interested if anyone has had a worn timing chain making a sound. I've heard videos of work chains / guides in a 22R-E engine and I have nothing which sounds like that.
EO
Is it throwing any codes?
My first thought was exhaust valves - but if you had them done 25k ago that may remove them as a cause.
My Saturn has a timing chain and it's been said that the chain will wirr like a chainsaw low on chain lube when it's time to replace it. Also the tensioner extension length on the Saturn 1.9l beyond 3/8" equals it's time to replace the chain. There should be something like that for your 2.7
