2 questions, Floor mats? & Trailer light hookup?
Markjr
I have a manual transmission so my aftermarket floor mat constantly needs to be adjusted because it slides everywhere! Is the dealer the only place to buy the mats with those special hooks? I have the insert piece in the floor I just need the mats that have the hooks.
Also, where do I find the wire connection for trailer lights? My Runner has the towing package but I cant find the wire hookup, someone said it could be wired from the tail lights. Thanks for any input
Husky Liners also come with a punch out hole for the clip to attach.
I would recommend those over mats any day.
Regarding the trailer connection-in theory it should be attached right at the hitch cross bar. Crawl underneath near the spare tire and just see if someone zip tied it up out of the way for some reason.
If you are totally lacking that 4 pin pigtail from inside the vehicle then Hopkins makes a plug and play product for our 3rd gens. that attaches to one set of tail lights and then snakes out the rear cargo area to the hitch. It replaces the Toyota factory converter black box-which seem to fail pretty often.
It's a bit of a pain to remove those cargo area side panels. Take your time to not break the clips or their mounts. If you'd rather just remove one side instead of both then double and triple check the location of the trailer light converter black box for your vehicle.
On my 99 that magic black box was behind the drivers rear cargo area panel.
Pretty sure I have this topic covered in my Facebook pic link. If you need further help I am glad to help.
AlaskaRuss
