2000 4Runner warm start problem
tomzapf
I have a 2000 4Runner Limited 4x4 with about 110 k on it. It always has been running perfect and I treat it like my baby.
Recently about a month ago I noticed that it has trouble starting when its warm, lets say I drove for a while parked and turned the engine off for few minutes and try to start it back up, it turns perfect (I don't think its a starter problem) but the rpms go down and it dies out even sometimes. I then have to press the gass pedal to keep it alive for that second, and then its fine.
Timing belt has been changed, regularly maintained and tempered. Cleaned out the MAF sensor, replaced O2 sensor and cleaned out throttle body. Still same issue, I would appreciate any responses.
Hi,
Sounds like a dirty IAC valve. Common problem on the 3.4L. Yotatech.com has a couple of writeups on cleaning it. Fairly easy job and only a couple of gaskets are needed.
Thanks for info. I'll try to clean it this weekend and next and see if it helps, I'll let everyone know. thanks.
