2000 Limited "5 Button TDS?"
TripWire
Anyone seen any information or wiring diagrams on a "5 Button TDS" security system? Evidently, this was a dealer add-on to the 2000 Limited. All I can find is Main Module Part Number 00016-30988-01 and Immobilizer Compatible Remote Start Module 00016-30988-52 (Google returns nothing for these numbers).
Remotes wore out a long time ago and now it will occasionally just go off when I open the door. Without the remotes, you have to go through a procedure with the valet button to stop the alarm that sometimes works, sometimes does not, and meanwhile, the damn horn will not stop.
This system is strapped beside and underneath the steering column. I'd like to completely disable the thing but I found out when I disconnected any of the main ECU module or remote start module connectors it enables the immobilizer and the engine will not start.
6 or 8 vampire taps connect it to the existing car wiring, but again, I am afraid to start disconnecting all of that not knowing what is enabling the immobilizer.
Laredotx
