2001 4runner 138k sludge
liljoe113
i just purchased a 2001 4runner a couple months back. yesterday i changed the valve cover gaskets and spark plugs. i discovered inside the valve covers was alot of sludge. i have a couple questions.
1. should i use C foam to flush it?
2. can i switch to synthetic? there are no leaks presently but worried by switching that i will create a leak.
3. right now my plan is to switch to synthetic and change oil every couple thousands to gradually flush the sludge out.
any input would be appreciated.
thanks, joe
do a search on this topic as there are countless threads about and how to treat that sludge. the sludge could be preventing a leak. you start flushing and change to synthetic you could start a leak because of the smaller molecules in the synthetic.
Technically the molecules in the synthetic are not really smaller, in fact many of the molecules in petroleum oil are smaller.
Difference is that quality 100% synthetic all of the molecules are all the same size and are long chain that resemble something like a backbone.
Regular petroleum goes from super small to extra large molecules and every shape and size, it also has several naturally occurring contaminates like sulfur, wax, salt, etc that burn off and leave deposits and change the viscosity quickly.
Heat and Oxygen are what breaks oil down
Petroleum oil the minute you fire up your engine after an oil change has already changed and started burning off the very small molecules. This puts a larger load on the remaining oil molecules.
Not to mention what those really extra large molecules do is basically blanket the metal surface while the tiny molecules squirt around burning off. What this does is actually prevents the oil from doing its job which is to transfer heat from the metal to the oil. This is not a good thing considering oil is supposed to do about 50% of your engine cooling. Also having sizes from very tiny to extra large creates more friction which creates more heat which breaks down the oil faster.
Its sort of like if you take 2 plates of metal and put thousands of the exact same size ball bearings between them it should have very little friction and roll very easily, then take bearings the size of BB's up to the size of a baseball and many sizes in between and see how that rolls, lots of friction.
Petroleum oils have oxygen IN the base stock as a contaminate from the get go and because a large percentage of the molecules in petroleum are tiny they burn off and form a varnish, the sulfur burns off, the salts, the wax and on & on and all these things burning off and turning to acid breaks down the oil way quicker and cause sludge. What sludge is, is Oxidized oil and burned contaminates.
Real 100% synthetic suffers from none of these problems, no naturally occurring contaminates all the molecules are uniform in size (monomolecular) have a higher TBN to start with, don't have any wax so are usable in far lower temps and flash point is much higher. Which does not mean that 100% synthetic will never sludge, just means it is less likely and you really have to ask for it. Like never changing your PCV valve, using cheap oil filters and running the oil for 12,000+ miles regularly you would be asking for it.
First thing I would do is change the PCV valve which could have caused the problem in the first place.
Then get the cheapest petroleum oil you can get, its all pretty much the same manure, don't get high mileage or semi synthetic, just cheap 5W30 plain old oil.
I would run 3 bottles of AutoRX through it and change the cheap petroleum every 2000 miles for about 6000 miles.
Then start using a true 100% synthetic oil after that with just 3-4oz of the AutoRX in it with each oil change and change the oil every 6000-8000 miles or 1 year which ever comes first. I have ZERO personal knowledge of this Autorx, never used it, seems like it works but who knows could be snake oil.
OR
Use Seafoam treatment which many here seem to like and then use a decent but cheap synthetic like maybe the Rotella T6 5W40 and change the oil every 2000 miles for several changes. Using a good detergent oil and lots of changes could help to clean it out. Then start using a quality 100% synthetic with 6000-8000 mile OC
that's what a lot say here. i've never used synthetic.
A much more detailed explanation than my own so thanks Nunyabiz. I know I see a lot of people spread that here and elsewhere but it's just not true. If that was the case, why would anyone ever switch to it?
I have to chime in here on the sludge issue. I started replacing one quart of motor oil with MMO (Marvel Mystery Oil). It has a mild detergent and over time, it works to clean out the engine. It's also inexpensive. I run it in my fuel and in my motor oil at every oil change. NO - I DON'T WORK OR REPRESENT MMO! I reluctantly tried it after a couple of years debating it. I am glad I did. My truck has never run better!!!! It's not a drastic and immediately clean-up of deposits. It works over time and keeps from loosening everything up at once and running the risk of clogging the oil pump. Try it and check the oil when you drain it. It will be very dark at first and every oil change afterwards, it gets a little less "dirty."
Deno91
