2001 a/c problems
ECHAPUT113
Sometimes the a/c will not blow air. I hear the compressor, but no air comes through vents. Then next time I start the car it works. Any ideas?
No. It will be working fine, and then I'll shut the car off, and when I start it again, NOTHING.
Sounds like the fan motor. Next time it won't blow, drop the glove box out and with your fist, give the back side of the motor a tap like your knocking on someones front door. If the motor starts up then that's the problem.
Thank you I will give it a try. Is that hard to replace?
Should be easy just a few screws and wire connection.
