2001 ATF questions
Whiplash Willy
I have 105k mi on my 4runner, and have no service history on it. I want to replace the transmission fluid on it to be safe. I took it to the dealer, and had them do a "Transmission Fluid Exchange".
They ended up putting in 4 qts of the ATF T-IV, instead of Dextron 3, which is what the FSM calls for.
Is it bad to mix the old Dextron 3 that was in there with the T-IV? Also, is it bad to use T-IV in a transmission that calls for Dextron 3?
The T-IV and Dexron are similar enough that they can (and are) be mixed regularly. I wouldn't worry about it.
If the dealer did a full fluid exchange, they probably would have used around 14-15 quarts instead of 3-4. I did the same thing and took my 2000 T4R (4WD) to the dealer and although I thought they did a full flush, they just dropped and filled.
Reading through these posts, I decided to do a full transmission flush myself to get everything out of the torque converter. I replaced with Mobil 1 Synthetic and it made a HUGE difference on a truck with almost 160K miles.
If you have the time and $$$, I would recommend you to do a DIY tranny flush, drop the pan, swap out the tranny filter and fill back up with Mobil 1 synthetic. Also, if you don't have a tranny cooler - it would be worth the investment to put one on. All of this stuff can be done by yourself without too much of a hassle. If you need more info - let me know
Thanks for the info guys! The dealer did a drain and fill, not a flush, so it was just 5 qts of T-IV they put in.
I think I will do a flush and fill myself, using that forum post as a guide, one of these days when I have some time.
One of the BEST darn write-ups on a full, DIY transmission service for a 3rd gen 4Runner is linked below. This is the one I followed and it turned out perfect. HIGHLY RECOMMENDED as it has lots of pics to follow! Good luck!
Dropping Pan And Flushing Transmission
:iagree: Awesome write-up and quotes the correct torque specs which is more than I can say for my FSM. 65 ft/lbs ≠65 in/lbs
Edit: I have seen at least one thread on here that argued T-IV and Dexron III were incompatible and would cause problems. One member stated that there was a TSB on the compatibility of the two ATFs but couldn't produce it.
What does your dipstick say? Dex or a bunch of Japanese and T-IV?
t4 and dex are listed as incompatible.
I realize this is an extremely old thread (I hope you guys are still active) but this link is broken for me, any other recommended threads?
Thanks,
Garrett
I found some muti-vehicle ATF made by Valvoline at O"Reilly's, and the label says it can be used in vehicles that use these fluids:
Ford MERCON applications
GM DEXRON-II and DEXRON-III applications
BMWLT 71141 and ETL 7045E applications
Nissan/Infiniti Nissan ATF, Matic D, Matic K,and Matic J applications
Mitsubishi Diamond SP-II and SP-III applications
Subaru ATF HP
Hyundai/ KIA SP-II and SP-III applications
Toyota/Lexus Type T, T-III and T-IV applications
Honda/Acura ATF-Z1 (except in CVTs) applications
Mercedes Benz NAG1 applications
Volvo passenger car applications (except AW-1)
Volkswagen/Audi TL52162
Have any of you used this?
What benefits did you notice from this switch and flush? I have an 01 that had an unknown fluid used before I purchased and I was considering flushing with Toyota fluid but I would like to weigh the Mobile 1.
Laredotx
