2002 4Runner purchase advice
tkheld
I am looking at a 02 4Runner 4wd. It is extremely clean with 99K miles. Asking 12K. The front right corner seems a little lower than the rest of the vehicle and the trans fluid is brown. Are this major red flags? Everything else looks like new. I have read the new buyer section. Would appreciate any input about what else to look for or double check.
See pics at Used Toyota 4runner SR5 2002 in Philadelphia, PA
Thanks.
12K is VERY steep for a 3rd gen. At the price you should look into a new 4th gen with less miles.
Thanks.
I would keep looking. It doesn't look like the TB and WP have been done (don't see a sticker on the shroud under the hood), so that is about 600 that you will need to spend right when you get the truck. I would find something less expensive, with more miles that has a maintenance history.
Thanks.
Should be perfect for that kind of money.
Looks like the sticker is right on the timing belt cover? just can't see it well enough to read it. Regardless, OP: wayyyy too much money for that. Pass. Brown tranny fluid? PASS!!
Just parroting everything already said; the only way that transmission fluid should be brown is if it's a manual transmission.
Usually the timing belt sticker goes on the passenger side of the timing belt cover
AndiGarage
