2003-2005 and 2006-2009 seat wiring help needed
iamBazzy
Hey guys, my ‘03 was in dire need of a full interior upgrade, and I scored everything I needed from an 09 at the local yard. Of course the seats bolted up just fine, but the wiring harnesses are totally different. Not only the connectors, but the color and number of wires per connector. Before tossing the old seats, I took their harnesses so I could reuse the connectors to the trucks harness. Does anyone have wiring diagrams for both these years? Or is there a write up anywhere? I’ve been searching for about an hour, but couldn’t find it. Both year seats are non-powered driver/passenger with the exception of lower lumbar support on the driver side. Any help would be greatly appreciated, thanks
I put some seats from an 06 in my 03. They were manual seats so it makes to process pretty easy.
-Just leave all the plugs on your 09 seats alone, take the buckles off of your 03 seats and put them on the 09 seats, plug them in to 03 plug.
-Unplug the lumbar wires off of the 09 lumbar motor, follow the wires up the seat back, and plug in the 03 to the lumbar motor, the plug on the motor is the same.
-The driver side is done at this point, the passenger seat you need to remove the weight sensor from the foam and stick it in between the foam and cover of the 09 seats, just plug it in to the 03 plug in the floor.
I looked up how to actually wire these in, and its a nightmare due to differences in airbag stuff due to the way the weight sensor is set up in 06-09 passenger seats...
***If they are power seats just wire them up with 12v to pins that are needed for seat power and then follow the process above
-If you want pictures ill get them to you
Circling back to this, I appreciate the help so far. Unfortunately I tossed the old seats while cleaning out the garage. I did snag the 06-09 truck harness connectors if that’s any help. I’d rather wire these in so they appear OEM, I don’t want to pull the seats apart and mess with the upholstery. Is there anyone else who has rewired 06-09 seats to the factory 03-05 truck harness? When it’s complete, will I need to run it by Toyota to have the airbag light reset? Thanks in advance
I went through this with my '03. My driver's side seat was worn and someone listed a brand new 2005 seat on CL. I ended up removing the '03 seat, putting them both onto a work bench and completely transferred the '03 harness over to the '05.
It's not hard to do, but does take a couple of hours. The '05 seat has an airbag in it, but my '03 didn't have that plug...just left it alone and connected up the rest of the harness.
If you threw out your old seat, well that's going to suck. The plugs on the '05 don't match to your interior harness. Good luck!
Go hit up a pull-apart... buy some trashed 03-05 seats. Thats all i can offer. The 06-09 seats will probably never be able to wired in correctly, the airbag ECU and seat weight sensors are completely completely different... Just do the steps i mentioned above.
My brother is an electrical engineer, He looked over the wiring diagrams and basically told me it was impossible, but i wish you luck.....
It’s just the passenger weight sensor that’s the issue if I got 03-05 seatbelts? Guess if it’s that impossible then I’ll have to disassemble it. We have a local yard with 10+ 4runners, I’ll have to run by
You also have to use the sliding track off of the 03-05 drivers seat. Just unbolt the torx bolts and attach the 06+ seat to the 03-05 base. There is a sensor on the sliding track that adjusts how the airbag inflates based on the seat position. You need this and it's different on the 06+ seats. I think this part slipped my mind in previous posts...
What yard around C. Tx has 10+ 4th gens in it?? I've only found a few lol.
2003 Toyota 4Runner Diagram.
2009 Toyota 4Runner Diagram.
Final Outcome?
iamBazzy, I'm in the same situation as you were in 2018. What did you end up doing? What was the outcome?
Funny, I logged in the other day looking for this old thread. I've been working on other areas of the truck, mostly exterior stuff. My local yard had a few 4Runners to pick over, so I grabbed the harnesses from a 2003 seat, as well as the seat belt buckles. I swapped the 2003 buckles onto the 2009 seats, but they didn't have the right connector.. I tried to look through some interior wiring diagrams to see what I need to do, but didn't have much success finding what I need. Nevertheless, I have everything I technically need to get this done, I just need to map it out and get after it this week
Thanks iamBazzy. Looks like I'll be heading to a junk yard as well to look at the harness for some seats. I have an eager 16 year old that is dying to hit the roads. Thanks for the update.
Thank you so much for this. Replaced my 04 with a 'brand new' 05 driver's seat. Took me about 2 hours jus because I was trying to be super careful. Hardest part was replacing the seat belt receptacle on the 04 harness. Tore up the housing a little bit getting it open. My original receptacle's spring was weak and wanted the new one.
BillM777
