2003-2009 Toyota 4Runner 32" Flush/Stealth Lower Bumper Brackets 15 Percent Off!
i have the stealth brackets, but does anyone have a solution to relocate the front plate? Either moving it down or DIY or otherwise. I considered drilling through the bumper cover into the bar right behind it, but haven't seen much on this site of anyone else doing that. thanks in advance.
Like this?
Sent from my ONEPLUS A5010 using Tapatalk
yes like that. did you bolt that into the bumper bar behind the cover? i don't think my lower grill pops out so it would be a little trickier but still doable i think. thanks!
I used the existing OEM holes on the backside of the bumper bar. Inserted #10 rivet nuts to secure the DIY mounting brackets. I cut out my lower grill.
APRIL DISCOUNT: 10% OFF LOWER BUMPER LIGHT BAR COMBOS
2014-2020 Toyota 4Runner 32" Hidden Grille LED Light Bar Combo
View Product
Has anyone wired one of the factory Toyota style switches lately? My CaliRaised harness has white, black, and blue and my Toyota style switch has black, green and two reds. Through some testing I did black to black, green to blue, and both reds to white which works, but makes the switch in the cabin illuminated at all times. Ideally I'd like the switch to only illuminate when the bar is on.
Edit: I believe I've got it, I had them flipped--black to black, green to white, both reds to blue.
Just to add to this: I did an AUXBEAM bar this weekend and their harness had black, red, yellow. The cabin switch I bought (from Caliraised) had black, green, and 2 reds. I did black-black, 2 reds to red, green to yellow. Button illuminates only when pressed (lightbar on).
Bunkstaff
