2003 4Runner Limited V8 - transfer case fill?
rfe1dotcom
I am planing on draining the transfer case fluid, I see the drain plug on the transfer case and I can feel the fill plug on top...But what do you use to get the oil in there?
Make sure you are looking at the right thing. You should be able to see, not just "feel" the plug. Blue circle below shows the fill plug. As was stated above, a pump will come in very handy.
Remember to take out the fill plug first. Imagine what would happen if you got the drain plug out and then couldn't get the fill plug out.
rfe1dotcom,
ASUMTNEER makes a good point. Your description makes it sound like you're dealing with the fill plug for the transmission.
I had good luck buying a pump used to fill outboard lower units. They are less than $10 at Walmart.
2001ATL
