All you have to do is unplug the connector, remove the 2 screws and pull it out. It will have some resistance because of the rubber o ring on it. Do not drop it or touch the sensors inside to case. Get a spray can of mass air sensor cleaner and give the two sensors inside 10 -15 shots of spray, let it dry and reinstall it. I noticed more power and mpg after doing this.
