2003 V8 4runner Actuator Leak Minneapolis
gutie050
Any toyota mechanics on the board that would want to tackle doing the oring replacement on my actuator? Located near Minneapolis
I experienced the same issue on my 04. Sadly, the shaft was bent which was ultimately the root cause of the leaking O ring. I took it to Toyota, as this job was well above my pay grade and had them replace the entire actuator. Almost 2 grand later no more leak and happy low and high. :cry::puke:
I'm only sharing worst case scenario hoping yours is just the O ring.
Check out carspec in Eden Prairie. I stumbled upon them when I was shopping for 4Runners and the failed 4x4 actuators.
Did you use their services? How is their pricing? Curious as they are close to my work and may be an option for me should I have an issue beyond my skills or time.
I called them once regarding the repair on a possible buy. Found another 4Runner so I haven't used their services, but they are very knowledgeable on Toyota's and Lexus. Since they are close to you, might merit a call to answer your questions.
I spoke with the owner he's a super nice guy. He recommended swapping the actuator. He said that the old ones can get pretty fragile and may or may not work when they replace the oring and reinstall them. $2700. I gotta find another solution here. I've got 230k on mine and it's not cosmetically great/my dogs and using it as a tool & supply hauler for remodeling has done a number on the interior. Struggling with putting that money into it.
I bought a whole transfer case used for $400. Mine is 203K already and there are lots of metal bits coming out the differential fluid. The one I bought had 70K . Once I can find someone to do it, Labor probably be $1K or so going that route. Cheaper than almost 3K , its too much hurt.
MMJR_T4R
