2003 vs 2007 sport step bars
Rayh78
Will the 2007 sport step bars fit my 2003.
States only 2007 to 2009.
Also a friend said some edition came with all black step tubs instead of the grey
Thanks for any info
I know that my NFab step bars came from a 5th Gen and fit my 2008 just fine, so I'd imagine any step bars would fit between 4th Gens similarly
Sent from my Pixel 5 using Tapatalk
Thanks for that info.
Did they just bolt right on. Or was there any drilling?
If you look up the parts on a Toyota site you will see some of the brackets fit 03-14 and others 03-09. It does look like the running boards themselves are different for 03/04 but I bet they'd still work seeing the brackets are the same, probably just look slightly different.
My limited came with running boards although someone removed them before I got it. I put others I bought on it. Not sure if all models have the holes but you could look. There's 3 brackets per side and each have two bolt holes for bolting onto the angled part of the underside of the floor. Pretty easy to spot.
I believe the side frames for the 03-23 are all similar. The body on top of the frame varies and so something designed for a 5th gen may be a little longer than a 4th gen.
As long as you have all the hardware - any 4th gen parts should go right in. With a little bit of creativity, you should be able to use 5th gen steps, rails too
AndiGarage
