2004 4Runner: How to install 10" shallow mount subwoofer in factory location
paraordnance
I started building my stereo a year ago when I finally had enough listening to JBL Synthesis for 5 years that I owned my 2004 4Runner. And this summer I finally decided to tackle the subwoofer enclosure. Right from the start I knew that all my stereo components will be away from eyesight. No flashy speaker grills, exposed tweeters, crossovers, cables, amplifiers or subwoofer boxes should be visible or in direct sight. I had experienced car stereo equipment theft before and was trying to be with my install, as stealth as possible. Two sets of 6.5" components in doors were providing some bass, but the low end thump was missing. I didn't want any subwoofer enclosures taking up my cargo area, I also wasn't prepared to spend $800 on the Stealthbox which still protrudes and sits over the wheel. I decided to build my own custom subwoofer enclosure in exact location where factory JBL subwoofer was. Building custom enclosure from MDF and fiberglass is a lot of work and patience, it took me over a month to complete this job but I was not in rush. I knew that the space is limited and I had to choose shallow mount subwoofer to achieve this. My top choice was 10" JL Audio 10TW3D4 400 Watt dual voice coil subwoofer with a mounting depth of just 3.5”. I bought one around Christmas 2014, on sale, brand new in box for just $250 CDN. A steal and a lot of bang for your buck, literally.
First I removed the rear right piece of trim which covers original subwoofer and amplifier.
2015-05-21_00004.jpg~original
Compared old vs new side-by-side
2015-05-21_00005.jpg~original
I installed subwoofer amplifier under the passanger seat. It is tiny (7x9") Hertz HCP1D which delivers 700 Watt RMS at 2 Ohm load, little too much power for this subwoofer but its always better more than less.
2015-05-14_00002.jpg~original
Next step is to remove original subwoofer box and amplifier combo. It looks like a plastic toy but original box is engineered and build quite well. It is also around 16 liters of volume and JL 10TW3 only needs 0.5 cu.ft which is around 14 liters. I figured if I replicate outside dimensions of the original box I should be pretty close and have a nice fit.
2015-05-21_00006.jpg~original
2015-05-21_00007.jpg~original
You can see from the pictures above that the shape of the void space behind rear-right quarter panel has irregular volume and tapered to the top and bottom from the middle. In the middle, where it is widest, we got about 7" clearence, and no more than 4" on top and bottom, ouch.... From that point I knew I will have to use fiberglass for rear wall to confront to shape of the quarter panel. I don't think with MDF alone this project is feasible, there is just not enough room.
First goes sound deadening everywhere, I used box of Hushmat (10300) for cargo area since it was cheapest. 10 sheets - 12" x 23" for 19 sq. ft coverage, overall on truck I used 50 sq.ft of this stuff lining each door on inside and outside as well as complete cargo area and around subwoofer enclosure. Don't skip on this, this is very important step for SQ if you don't like rattling body panels.
2015-05-21_00009.jpg~original
2015-05-21_00010.jpg~original
Due to custom nature of this enclosure I started with piece of cardboard which I later trimmed and used as template for front wall of enclosure.
2015-05-21_00011.jpg~original
Old vs new sub dimensions
2015-05-23_00012.jpg~original
New subwoofer has slightly less mounting depth compare to the old one, so I'm not worried of clearance issues
2015-05-23_00014.jpg~original
First panel sizing up
2015-05-23_00015.jpg~original
Other panels measured and cut
2015-05-23_00016.jpg~original
Enclosure starts to take shape, screwed and glued together. I don't remember exact dimensions since I had to cut each piece to fit
2015-05-24_00017.jpg~original
Once the MDF (I used 5/8" due to the small size of panels) box is built it was time to start fiberglass work
2015-06-11_00018.jpg~original
First goes several layers of masking tape because you don't want resin all over your panels or fighting removing it after if it seeps through. I had 3 layers in total, the best masking tape to work with was Scotch exterior blue tape in second picture. It sticks well and waterproof
2015-06-15_00021.jpg~original
2015-06-18_00022.jpg~original
First layer of fiberglass, I used combination of cloth and mat to achieve required box strength. Keep in mind to make it slightly bigger at this stage since you will be cutting to shape later on.
2015-06-19_00023.jpg~original
Second layer. Please ignore my sloppy job, it was first time in my life I worked with fiberglass so I have to admit some air bubbles happened in between layers. It is so awkward to work on vertical surface, inside of a truck cargo area, where resin dripping on you while you sucking on the fumes (I wore respirator).
2015-06-20_00024.jpg~original
Overall I laid 3 layers before I pulled the cured panel out. I had to trim it with dremel in order to extract ready fiberglass panel, it came out quite easily.
Next step is to fuse MDF and rear fiberglass panel together. I first cut the walls of MDF enclosure to approximate shape of the fiberglass panel. Then clamping together while laying another couple layers on outside and couple layers on inside to hold it all together. This is very time consuming task since I could only work on top or bottom side at a time.
2015-06-21_00025.jpg~original
After about 7 layers of fiberglass overall, the enclosure was finally finished! it came out really strong and I could jump on it without any worry. I lined inside and outside of enclosure with more Husmat and measured internal volume by filling it with water (make sure you coat entire enclosure from inside with resin to avoid any water absorption by MDF). I poured exactly 14 liters of water when it was full. 14.3 liters = 0.5 cu.ft, BINGO!
Ready for mounting and cosmetic work
2015-06-29_00026.jpg~original
2015-06-29_00027.jpg~original
I mounted this enclosure with same hardware and mounting points as original one, it fits like a glove and not going anywhere.
Now I need to hide all this mess and make it look nice
2015-07-01_00029.jpg~original
I glued some 1/2" plywood on top of MDF front panel to cover major gaps and cracks and then used wood filler first to fill large gaps and cracks
2015-07-10_00031.jpg~original
2015-07-10_00032.jpg~original
Once wood filler dries, you can sand it to shape and apply finer drywall spackling compound for final touches
2015-07-12_00036.jpg~original
Its starting to look like something!
2015-07-12_00037.jpg~original
2015-07-12_00038.jpg~original
I then color-matched some exterior paint to interior panels and painted the whole cargo area. You can leave it at that, but I had some carbon fiber vinyl laying around so I decided to use it in cargo area and interior trim panels. Carbon fiber look may not be everyone's cup of tea but I figured why not, vinyl can always come off later if I don't like it
2015-07-15_00039.jpg~original
2015-07-15_00040.jpg~original
2015-07-21_00043.jpg~original
Final results. Not exactly factory looking, but doesn't take any additional space in cargo area
2015-07-29_00047.jpg~original
2015-07-29_00048.jpg~original
I decided not to mess with recessed subwoofer rings etc, due to limited clearance from the back and the lack of proper tools at my disposal, such as router
2015-07-29_00049.jpg~original
Much prefer the look of subwoofer with the grill than without
2015-07-29_00050.jpg~original
I also wrapped in vinyl opposite side for some symmetry
2015-07-29_00051.jpg~original
Since I had a lot of vinyl left over and I got sick of slate/granite looking trim interior pieces of Limited, I wrapped all in vinyl as well to carry on the theme throughout interior.
Comaprison side-by-side
2015-07-12_00035.jpg~original
Old trim
20150718_103744_resized.jpg~original
2015-07-25_00044.jpg~original
New look
2015-07-29_00045.jpg~original
2015-07-29_00046.jpg~original
You may wonder, so how does it sound? Its sounds incredible! I did not expected so much punch and tightness from 10 inch subwoofer. I also installed bass control knob in armrest console for easy access. This way I can set bass to zero with a simple turn of a dial when riding with my little son, or crank it up when travelling on highway or when I'm in the mood.
Overall this is a best 10" subwoofer I have listened to. I set crossover in HU to play <80 Hz for sub and >80 Hz for 6.5" components.
Overall I'm very happy with final results and sound quality coming out of speakers or sub.
Nice work. I have a 5th gen with the cubby there. I started to make a box out of MDF to fit in the cubby but way to many angles on the back to make it work right. Thought about building a fiberglass enclosure in the cubby that I could pull out if I ever sell it.
Might go the route you did and just remove the cubby and build the box into the wall. Something to think about.
Not sure I am ready to tackle fiberglass but would be fun to learn.
I originally planned to make enclosure out of MDF entirely, but once I started cutting panels I realized due to limited space, angles and MDF thickness it would be almost impossible. Fiberglass part was not that hard, probably the most fun! But stinky and messy if you not careful.
goddesszilla
