I have a 2004 4Runner and have noticed lots and lots of rust underneath the whole under carage of the 4Runner. This rust does not bother me as much as the rust spot on the rear trunk above the window seal. I first noticed the rust spot looking bubbling with orange rust running down the rubber seal. *I thought this was only exterior surface rust so I pulled out my sand paper, tape, wire wheel and drill. I taped off the area to work on and started with using the wire wheel with the drill on low. And the wire wheel exposed the rust had eaten all the way through the metal and the hole was much bigger than what it seemed. The hole is about 2 inches x 1 inch.
So yeah, rust spot is worse than thought and is now a hole in my vehicle. I am really pissed by now and need some help on thoughts and what I should do now?
***I have heard of people talking about using the TSB and going to their local Toyota Dealer and showing the rust and TSB printed off and they get the rust fixed. Does anyone think the TSB would help in this case? I have noticed some things on the TSB about paint and what not. Please help, thanks.
Location: Above the rubber window seal and almost directly behind the spoiler.
Vehicle: 2004 4Runner SR5 4x4 - Silver
TSB:
TSB for 2004 Toyota Truck 4 Runner 4WD V6-4.0L (1GR-FE) Technical Service Bulletins
TSB:
