2004 4runner sport 4wd maintenance do it yourself question
klay23
newbie question here.... the 4runner has 62000 miles and just had an oil change........
what other things should and could I do, I can read and follow directions........LOL and can use a wrench....
any help would be greatly appreciated... would love for this truck to last 200,00 miles... brakes, lube, fluids, ZERKS(not sure what that is or if I have them) and timing belt and ETC....
I would highly recommend changing the rear differential fluid. I just changed it on my T4R with 50K miles and it was in a pretty bad shape. I checked the front diff and the fluid looked brand new so I didn't change it. I also changed the transfer case fluid although it was in a pretty good shape and I probably didn't need to change it but I did because I wanted synthethic gear oil in there. Also if you have a V6 change the spark plugs. And don't forget to grease the drive shafts.
Here is a link to an excellent DIY:
http://www.toyota120.com/html/driveline_service.html
I actually printed out and used the above DIY guide to change the diff and transfer case fluid with Lucas Synthetic. That guide saved my life!
