Where Can I get the Maintenance Schedule?
kipmc7
Junior Member
Just a simple table showing :
Oil Change every XXX Miles or YYY Months
Air Filter
Spark Plugs (for the V8)
Cabin Air Filter
Brake fluid
Coolant
etc. Thank you. My Owner's manual says, "Please refer to the “Scheduled Maintenance Guide” or “Owner’s Manual Supplement. "
I have that but it does not say to change the spark plugs on a V8 only for the V6. That is note 2. It also does not say to change the transmission fluid only to inspect and the same for brake fluid. Do neither of these need to be changed ever??? I have done both of these in the past but I would like to see the Toyota recommendation in writing.
Thank you
I have tried to follow many of the links on here and they did not work, perhaps they are too old.
Thank you
Air Filter
Cabin Air Filter
Brake fluid
Coolant
Thank you
Thank you
Not enough info, what year???
But you can get the OEM "Maintenance" book that comes with the vehicle when new in PDF form from Toyota owners website, that's all you will get from Toyota.
Toyota Manuals and Warranties | Toyota Owners
On the V8 plugs, go to the plug you choose manufacturer's website for when to change them, on the iridium plugs it's around 60,000 miles but most owners says 90,000 miles(Not sure where they got that from).
The following about the iridium plugs is in my book for my 2004 on page 51....., just an FYI Denso makes the "Toyota" iridium spark plugs.
"Genuine Toyota Platinum and Iridium Spark Plugs *
• Designed to last at least 60,000 miles.
• Provide the maximum spark required by Toyota’s high-compression engines.
• Resist fouling and misfires for more efficient combustion and better fuel economy"
turbomikee
