Okay, so I tried a new horn and no dice. I took the steering wheel apart to try and understand how it works but can't see anything obvious that would inhibit horn function. The wires are in good condition and nothing is loose. I hooked up a volt meter to the wires at the horn and the steering wheel, but didn't get any reading. Maybe I'm not checking correctly.
Is there a separate relay that I need to check or maybe a part in the steering wheel that can go bad over time? Tried to follow the wires, but that's nearly impossible. I was in a front-end collision this last winter, but it didn't wreck anything past the bumper mounts. For the life of me I can't remember if the horn worked back then or not. Hardly ever use it. Of course now that its out I find myself needing it.
