2004 Navi Update
I'm using Nero 6.6.0.6
-I open Nero, then I chose Image Recorder as the Drive instead of the DVDR DL...
Then I select Recorder from the Top bar, and scrolled to Copy Disc...
Then It tells you to insert the "Original"
I do that, and name the file "map" and select the drive to dump it on...
It creates a file "map.nrg" which is the dump of the disc.
Then you can double click on the "map.nrg" and it prompts you to insert blank..
Voila.. BACKUP made... I used Verbatim discs, I think cheap media is exactly that. CHEAP.
j0.
Can anyone tell me what the part number for that 4.1 Nav update is? i got one off ebay but it didn't work in my 4Runner and the dealer will not give me any info. Thanks for the help.
