2004 v6 transmission drain and fill 5qts?
lj4r
Member
I have a 2004 v6 with the dip stick transmission. 225k miles. I don’t recall if the transmission fluid has ever been replaced. Color of the old fluid was medium brown. Not black, not red.
I did a drain and fill of the transmission. I had read that the drain would result in 3.8 or so quarts. I carefully measured the amount drained from my transmission, 5 quarts. I refilled with 5 quarts. Shifted through the gears several times and checked the fluid level. It was about 1/2 quarts below the full/hot Transmission shifts like new.
(Now I need to replace the left front caliper, again. Dang pistons keep seizing. This is the third time in 25,000 miles. O’reilly’s rebuilt calipers are junk. Live and learn).
Simple project.
Phil
H.Sikina
