2004 with 143,000 miles
DrumGolf
Hey guys,
I just want to thank the folks on here that have helped me in the past and this place is truly a storehouse of knowledge! I am taking my 4runner in for some much needed maintenance and was wondering if you guys had any input on what you think should and should not be done. This is what I have so far...by the way it runs like a champ, I did the spark plugs at 120,000 and have kept the tires rotated and oil changed every 5,000 miles. Thanks in advance!
oil change
tire rotation
accessory belt replacement
transmission flush
4x4 serviced (front and rear differential)
Anything else you can think of or just leave the list as is?
check power steering fluid, clean throttle body/fuel system and I read a write up on doing the serpentine belt yourself...which will save you a lot of money that way and shouldn't take more than 20 minutes.
The fluids in the transfer case and both differentials need to be replaced for sure but that's another one that you should probably do yourself. It's real easy and not worth paying some else $300 or more to do.
your coolant, power steering fluid, brake fluid
Hey guys,
oil change
tire rotation
transmission flush
