2005 Land Rover LR3
POWERTRAIN
Globally, three engine choices are offered on the Discovery 3, headed by a 4.4-litre petrol V8, specially adapted from the engine used by Jaguar. Also new is an outstanding TDV6 turbodiesel, one of the most sophisticated diesel engines in the world and expected to be the best-seller in Europe (not available in North America). Selected markets will also take a second petrol unit, a smooth, torquey and durable 4.0-litre V6.
A state-of-the-art ZF ‘intelligent shift’ electronically controlled six-speed automatic gearbox is available with all engines. In addition, a ZF six-speed manual transmission is available with the diesel engine, and is likely to prove especially popular in mainland Europe.
Jaguar-derived Petrol V8
The top-of-the-range engine in the Discovery 3 is a Jaguar-derived V8. The most powerful engine ever fitted to a production Land Rover, this 4.4-litre unit gives superb performance both on-road and off. This quad-cam (double overhead camshafts per bank) 32-valve unit is one of the world’s lightest V8s, owing to its compact dimensions and its employment of lightweight aluminum alloy block and heads.
For Land Rover use, water-proofing, oil circulation, dust-and-mud protection and breathing were all modified, to cope with the additional challenges of climbing mountains and wading rivers. The engine ‘mapping’ has also been revised, to serve up more low-end torque, and the bore size has been increased from 86 to 88mm.
The upshot is a larger capacity – 4.4 liters as opposed to 4.2 in Jaguar guise. Maximum power is 295bhp (220kW). Though this is slightly less than the equivalent engine used in the Jaguar XK, XJ and S-Type, maximum power is developed at lower revs, 5500rpm rather than 6000. Torque has been increased, and is also delivered at lower revs: 425Nm (315lb.ft) at 4000rpm.
The engine is not only light, it is also renowned for its thermal efficiency. This improves economy, and helps with warm-up times and driving behavior.
The engine uses an electronic throttle and Variable Camshaft Phasing (VCP) – which automatically and continuously controls valve timing according to driving demands and outside temperature.
Oil capacity has been significantly increased, from 6.8 liters to 8.6 liters, to cope with the need to supply oil even at the extreme driving angles a Land Rover may face. The oil pump is new, for improved delivery of the lubrication, and the front crank oil seal is also modified, to guard against ingress from water, mud or slurry during wading or other off-roading conditions. The aluminum oil sump is new, and engine ancillaries are repositioned as high as possible – to prevent damage when off-road.
Outstanding New TDV6 TURBO Diesel
The new high-technology TDV6 turbodiesel for the Discovery 3 is a sister engine to that recently launched in the Jaguar S-Type, to great acclaim.
The unit uses common rail technology and operates at even higher pressure than most common rail injection systems – about 25 per cent greater than average – benefiting performance, economy, refinement and emissions. Maximum power is 190bhp (140kW) at 4000rpm and maximum torque is an enormous 440Nm
(325lb.ft), developed at only 1900rpm.
Apart from its high injection pressure, other technological innovations include the use of a compacted graphite iron (CGI) engine block. It is one of the first uses of this material in volume engine production. CGI is stronger, stiffer, lighter and more durable than cast iron – from which diesel engine blocks are usually manufactured.
This inherent stiffness helps driving refinement, and its strength and lightness allow the engine to have less mass and smaller dimensions than a traditional V6 turbodiesel. The stiffness and strength also remove the need for cylinder liners: the cylinders are bored directly into the block casting, saving further weight.
The cylinder heads are pressure die cast in aluminum alloy, and each carries two overhead camshafts operating four valves per cylinder. The camshafts are driven by a flexible belt coated in PTFE to reduce friction. To increase both reliability and precision, the camshaft belts drive no other system.
Unique to its Land Rover application, the TDV6 turbodiesel has an aluminum ladder-frame at the bottom of the crankcase, to improve rigidity. Its baffle plates prevent oil foaming and surge when off-road. Attached to the ladder-frame is a pressed steel sump, also unique to Land Rover. The oil pick-up point is optimally designed to operate at acute off-road angles.
The TDV6 turbodiesel runs with a compression ratio of 17.3:1, relatively low for a diesel engine. This reduces heat build-up in the piston bowl, improving fuel burning efficiency, and reducing fuel consumption and emissions. The low compression ratio also reduces engine noise.
The inlet manifold is made from composite material and is moulded integrally with the cam covers. It is isolated from the cylinder heads by an electrometric material to reduce vibration. There are two inlet ports for each cylinder. One is a ‘filling’ port, designed to get as much air as possible into the cylinder, while the other is a helical ‘swirl’ port to generate the vortices necessary for optimum fuel combustion. In certain part-load conditions, the engine management system closes the ‘filling’ port to increase the swirl effect. This alters the combustion characteristics, reducing emissions and noise. The engine control unit is also unique to Land Rover and takes information from more than 20 sensors around the engine.
Turbocharging comes from a single KKK unit for optimum torque (the equivalent Jaguar engine has twin turbochargers) fully sealed to suit wading. The turbocharger uses an electronically controlled Variable Nozzle Turbine which ensures that air delivery is optimized by altering the angle of the turbine vanes. It effectively widens the turbine inlet at low speed to improve torque and narrows it at high speed for better power response. The engine is equipped with a glow plug in each cylinder to assist in cold starts. The TDV6 turbodiesel also meets EU3 emissions legislation, and has the potential to satisfy all known future legislation.
Smooth V6 petrol
Available only in selected markets, the Discovery 3’s gutsy and smooth 4.0-litre V6 petrol engine offers good performance and economy. Maximum power is 215bhp (156kW) – 13 per cent more than the 4.0-litre V8 engines of the outgoing Discovery model. Maximum torque is a substantial 360Nm (265lb.ft).
The Ford-derived engine uses a cast iron block and aluminum alloy heads. The crankshaft is counter-balanced for extra refinement.
Extensive modifications for Land Rover use include a die-cast aluminum ladder-frame on the bottom of the block to stiffen the structure, with baffle plates to stop surge and oil foaming. The revised sump includes a new oil pick-up pipe to improve lubrication at all angles. The alternator, air conditioning compressor and power steering pump are all unique to Land Rover, and are positioned as high as possible to keep out of harm’s way during extreme off-roading.
A new, cast aluminum variable-tract inlet manifold has been developed for the Discovery 3. Controlled by a new engine management system, it improves torque and driving characteristics. The lower profile manifold also helps under-bonnet packaging. The electronically controlled throttle regulates torque delivery as efficiently as possible. It is also linked to Land Rover’s patented Terrain Response system, and regulates engine response accordingly. Oil seals have also been changed, to improve water- and dust-proofing.
Six-speed Gearboxes, including ‘intelligent shift’ Automatic
For the Discovery 3, petrol engine vehicles come exclusively with the advanced, six-speed ZF automatic transmission. For TDV6 models, there is a choice of this automatic or a six-speed manual gearbox.
The ZF 6HP26 transmission is one of the most advanced automatic transmissions in the world. As well as offering normal automatic operation, the gearbox offers a ‘sport’ mode that alters the timing of gear shifts and throttle response. It also features ‘Command Shift’, giving the driver full manual control of gear changes. In high range, this will protect the engine by automatically changing up or down to prevent over-revving or stalling. In low range, this is overridden to allow move-off in a higher gear, which can be useful in slippery conditions.
The gearbox also analyses road conditions and each individual’s unique driving style, automatically tuning its response accordingly.
The case is unique to Land Rover, and is especially stiff. The sump is also unique. The gearbox electronic control unit is housed within it, for extra protection. This communicates, via a high-speed link, with the Terrain Response system.
The manual gearbox, available only on the diesel model, is also manufactured by ZF. This six-speed unit, with a unique casing and full compatibility with Terrain Response, is likely to be especially popular in mainland Europe, where manual diesel vehicles dominate the 4x4 market.
Transfer Box and Differentials
The two-speed transfer box features an easy-to-use electronic shift, to move into low range (for off-road) or high range (for on-road). The change can be made on the move.
For added traction, the centre differential is locked electronically when conditions require.
A lockable centre differential is a feature offered only on serious off-roaders, and enables the vehicle to crawl, at low speed, over difficult terrain with more stability and less slip.
An electronically controlled locking rear differential (known as an ‘E-Diff’) is also available with Terrain Response™. Locking of the rear differential is controlled by an electronic control unit linked to the operation of the centre differential.
All three differentials used in the Discovery 3 – forward, centre and rear – are unique to the vehicle. They are mounted directly onto the chassis, a move which is designed to maximize ground clearance for improved off-road agility.
DYNAMICS
At the core of the Discovery 3’s outstanding on-road and off-road dynamics is the all-new Integrated Body-frame, a Land Rover patented technology.
"This innovative new vehicle platform architecture has enabled us to combine the advantages of a monocoque with traditional body-frame off-road strength," says Discovery 3 chief programme engineer Steve Haywood. "It delivers the comfort, refinement and on-road attributes of a monocoque, while setting new standards for off-road performance."
OUTSTANDING ON-ROAD AND OFF-ROAD DYNAMICS
The Integrated Body-frame is unique to – and was developed by – Land Rover, and is crucial to the dynamic excellence of the Discovery 3. It carries the body and the suspension, it encloses and protects vital electronic and mechanical systems and it provides a stable platform for the vehicle’s many electronic controls.
"Its advantages over a conventional ladder-frame include lower weight and greater rigidity – which aid handling and ride, especially on the road," says Haywood. "Its benefits over a monocoque (or unitary) body are its strength and ruggedness."
The new frame structure is special because of its advanced computer-aided design techniques, its trend-setting hydroforming production process and its use of advanced high-strength steels. The result is lightness, great strength and an unusually complex yet efficient shape.
The technique of hydroforming uses fluid pressure to form shapes. It allows for a much greater variety of shapes and sizes than conventional tooling, and also allows for tighter tolerances, increasing precision and reducing weight. It is especially useful for single large components, which would otherwise be made from multiple stampings, bolted or welded together. Using high-strength steel, the result is a frame that is structurally stronger and substantially stiffer, yet lighter.
The flexibility of hydroforming allows engineers to design an optimum frame shape, unencumbered by conventional production compromises. The shape can be much more complex and much more efficient. The side members on the Discovery 3, for instance, are much more curved than a conventional ladder-frame, allowing for width in the centre section but a tapered front, which improves the turning circle.
The complex frame shape also improves crash performance, boosting passenger and driver safety. Substantial side members protect the Discovery 3 from side impact, and the rear structure of the body-frame is designed to protect the fuel tank and filling systems.
The Integrated Body-frame assists both on-road and off-road performance. It gives a low centre of gravity, by keeping major weight as low as possible. The production versatility of the frame allows for the rear drive shafts to pass through the chassis frame, obviating the ‘swan neck’ of other designs. This not only protects the shafts, it helps lower the centre of gravity and allows the floor to be unusually flat.
The frame design improves off-road performance by minimizing front and rear overhangs, to give outstanding approach and departure angles. Vulnerable systems, cables and pipes are packaged between the frame members to protect from damage. By carefully placing key components inside, through, or around the frame, the underside of the vehicle has been kept extremely smooth, minimizing the risk of obstacles being snagged when off-road.
ADVANCED AND USER-FRIENDLY TERRAIN RESPONSE™
Land Rover’s new Terrain Response™ system – standard on all Discovery 3 models with air suspension – is an advanced but user-friendly technology that optimizes vehicle drivability and comfort, as well as maximizing traction. Simply select one of five Terrain Response™ settings to suit the driving conditions and a multitude of the vehicle’s functions are tuned to deliver optimum performance. Accessed via a rotary control in the centre console, the five Terrain Response™ programs are for:
• General driving
• Grass/gravel/snow*
• Mud and ruts
• Sand
• Rock crawl
* For various slippery conditions, on-road or off-road
Terrain Response™ uses a high-speed electrical architecture network to control the relevant vehicle features, systems and technologies, including:
• Engine management system: the throttle map is altered, improving drivability by suiting torque delivery to the chosen terrain
• Electronic control system: of the automatic gearbox, to optimize gear-change points
• Air suspension ride height: automatically adjusts to give maximum height in the ‘rock crawl’ and ‘mud and ruts’ programs. This is also automatically activated whenever low range is selected
• Dynamic Stability Control (DSC): normally stops torque to a wheel after loss of traction, but in some off-road situations torque feed is still desirable, even when traction is being lost. Terrain Response™ automatically adjusts the DSC, so appropriate torque is maintained
• Electronic Traction Control, Brakeforce Distribution & Anti-lock Brakes: these slip and braking control systems are all adjusted and tuned by Terrain Response™ to offer optimum grip, braking power and safety on the chosen terrain
• Hill Descent Control (HDC): the Queen’s Award-winning Land Rover technology that automatically restricts speed downhill, using the anti-lock brakes, and enables drivers to remain in control even on the most slippery of downhill stretches. HDC is automatically engaged on all programs except ‘general driving’, and downhill speed rates vary depending on which surface is selected (in ‘rock crawl’ the lowest speed is selected to prevent vehicle damage)
• Electronically controlled centre and rear differentials; with different slip or locking rates for the different terrains
The Terrain Response™ system works continuously, with the ‘general driving’ program optimizing the vehicle set-up for everyday on-road use. However, it is the off-roading programs that demonstrate to the full Land Rover’s unique experience and expertise.
"We analyzed the characteristics of nearly 50 different types of off-road surface, and determined the vehicle system inputs necessary to optimize performance on each," says chief programme engineer Steve Haywood. "We concluded that these can be distilled into just a handful of programs – and those are the settings we offer on Terrain Response. It’s like having an expert alongside you, to help you get the best out of the vehicle, whatever the conditions, and on-road or off."
Terrain Response™ was previewed on the recent Range Stormer concept car and is making its production debut on the Discovery 3.
FULLY INDEPENDENT SUSPENSION WITH CROSS-LINKED AIR SPRINGS
For optimum on-road handling and refinement, the Discovery 3 is fitted with fully independent suspension front and rear, which gives much greater driver feedback, car-like handling, and good on-road ride.
Double wishbones are used front and rear. This is an optimal set-up for on-road handling and refinement, and yet on the Discovery 3 it also offers generous wheel travel – 255mm at the front and 330mm at the rear – for excellent wheel articulation and off-road traction.
Coil sprung suspension is standard on entry-level models, and is used in conjunction with hydraulic dampers. This is a tough, well-developed solution, to offer a good ride/handling balance. However, all higher series Discovery 3 models feature cross-linked air suspension, increasing on-road refinement, off-road capability and overall versatility.
The air springs are computer controlled, giving automatically softer or firmer springing, depending on road or track conditions. They are also cross-linked, further aiding off-road capability. Special software detects off-road driving and cross-connects the system. Air displaced by the upward movement of an air spring is transferred to the spring on the opposite side, forcing it down, improving composure. This mimics the action of a traditional beam axle, by boosting articulation and improving wheel contact.
The air springs also provide a range of ride heights for the Discovery 3. This is useful on-road, improving access to the vehicle by selecting the ‘low’ height setting, and off-road, where the ‘high’ setting gives extra ground clearance. These height settings can be easily selected manually, by a simple switch, or can be set automatically by the Terrain Response™ system.
Tires are specially developed to suit this multi-purpose vehicle and, as with all original Land Rover fitments, are suitable for on-road or off-road use. All wheels are alloys, in sizes from 17-inch (235/70 tires), through 18-inch (255/60 tires), likely to be the most popular choice, to 19-inch (255/55 tires).
ELECTRONIC AIDS IMPROVE TRACTION, BRAKING & HANDLING
The Discovery 3 has an advanced full-time 4x4 system, but to improve grip further in all conditions, this is supplemented by some of the most advanced electronic controls in the automotive industry.
Electronic Traction Control (ETC) ensures that grip is optimized in all conditions, by automatically reducing wheelspin to any tires losing grip. The Dynamic Stability Control is another computer controlled aid that seamlessly, and without any driver involvement, ensures that the vehicle heads in the intended direction, avoiding skids or any other potential loss of control. Like ETC, it is especially valuable in slippery on-road or off-road conditions.
Land Rover’s patented Hill Descent Control (HDC) is fitted to the Discovery 3. This Queen’s Award-winning technology regulates downhill speed, ensuring that the driver stays in control even on slippery, steep descents.
All these technologies are linked to the standard four-channel ABS braking system. Two different braking specifications are offered, depending on vehicle specification. Both provide large ventilated disc brakes all round, with twin-pot sliding calipers at the front and single pot calipers at the rear.
The more powerful braking system, used with the V8 engine, offers 337x30mm front and 350x20mm rear discs. The other system uses 317x30mm front discs and 325mmx20mm rear discs. Electronic Brakeforce Distribution (EBD) provides optimal braking regardless of the way the vehicle has been loaded, adjusting front-to-rear braking balance automatically. Emergency Brake Assist (EBA) automatically boosts pressure to the braking system if emergency braking is detected, reducing stopping distance and improving safety.
For the first time on a Land Rover vehicle, the Discovery 3 features an Electronic Park Brake, which frees up the space in the centre console taken by a conventional handbrake. It is applied by a console-mounted switch and disengaged automatically when driving off.
PRECISE RACK-AND-PINION STEERING
The Discovery 3 has hydraulically-operated, power-assisted rack-and-pinion steering, which is both linear in feel and intuitive. The rack is mounted directly onto the frame to improve response and rigidity. It is protected from rocks and other off-road snags by a substantial body-frame cross-member.
HEADLAMPS THAT ‘SEE’ AROUND CORNERS
The Discovery 3 offers as an option one of the most advanced lighting systems in the world, featuring headlamps that swivel when cornering. Linked to steering angle, vehicle speed, axle position and gear selection, they improve illumination and give the driver a better idea of what lies ahead.
Entry-level models feature twin-pocket halogen headlamps, while the mid-line system uses bi-function xenon projectors with auxiliary halogen main beam lamps. Optional fixed cornering lamps are also available (except for North America).
High-level models get an adaptive front lighting system (AFS). Linked to the vehicle’s sophisticated electrical architecture, AFS receives information on vehicle speed, steering angle, axle position and gear selection. Analyzing this information, the projectors swivel left or right accordingly. Additional static bending lights (not available in North America) are mounted at 45 degrees to the car line, and give extra light to the direction in which the car is turning. They are also illuminated at low speed to assist with maneuvering or parking. AFS also features dynamic leveling.
Front lights are protected by tough polycarbonate covers and have optional pressure wash. The rear lights are mounted high on the rear corner pillars for good visibility.
TESTING
FOUR MILLION TEST MILES
The all-new Land Rover Discovery 3 has gone through one of the toughest and most varied testing programmes of any vehicle ever offered for sale.
It has been put through its paces over four million miles on five continents, in conditions as varied as the Nürburgring race circuit in Germany and the sand dunes of Dubai. It has been tested to extreme in the Australian outback, been punished on military off-road tracks in both Southern Africa and England, been driven at minus 40ºC on frozen lakes in northern Canada, and undertaken 12 weeks of almost non-stop testing at maximum speed on the Nardo test track in Italy.
"We believe few, if any, vehicles have ever undergone a more punishing and varied series of tests," says chief programme engineer Steve Haywood. "The Discovery 3 promises the broadest range of capabilities in its sector. This combination of on-road and off-road ability was the reason the vehicle needed such a rigorous testing programme."
OFF-ROAD TESTING
Land Rover has a uniquely exacting off-road testing schedule, arguably the most demanding of any vehicle manufacturer. The Discovery 3 had to be able to wade in water 700mm deep, climb and descend 45 degree gradients, remain stable when driving across a 35 degree slope, and operate in temperatures as extreme as minus 40ºC and plus 50ºC. The handbrake must also be capable of holding the vehicle on a 45 degree slope.
An enormously varied testing programme was devised to prove the Discovery 3, with much of the fundamental work naturally undertaken in the UK. Eastnor Castle, in Herefordshire near the Welsh border, was used for testing the car’s ability through water, on slippery grass and in deep mud. Further river wading skills were tested on private estates in Scotland. Durability testing was carried out on army test tracks in southern England, at Bagshot, Surrey, and Bovington in Dorset, home of the Royal Armored Corps. These facilities are more usually used for destruction-testing tanks, so helped substantiate the toughness of the suspension and the new Integrated Body-frame.
Similar testing was carried out at a former military facility in South Africa, usually used for evaluating the strength and traction of armored vehicles. Southern Africa was also used for hot weather and dust testing, as was Australia, where vast distances were covered in the outback, including testing on vicious corrugated roads, notorious for dislodging trim and inducing rattles and squeaks in less capable vehicles. Dubai, in the Middle East – another Land Rover test favorite – was used for measuring and tuning the vehicle’s ability to climb sand dunes, and for general off-road ability. Also tested there was the efficacy of the new and advanced air conditioning system to keep occupants cool and comfortable even in temperatures as high as 50ºC.
Off-road testing was also carried out in northern Canada and in Sweden, where the vehicle’s performance in ice and snow was confirmed. So was its ability to operate efficiently and comfortably in temperatures as low as minus 40ºC.
ON-ROAD TESTING
"What’s unusual about the new vehicle’s testing schedule is the amount of time spent at locations more usually associated with sports cars than SUVs," says Steve Haywood.
High-speed testing was done at the famous Nürburgring circuit in the Eifel Mountains in Germany, where on-road handling and braking performance were pushed to the limit. The original Nürburgring track is recognized as probably the most punishing and demanding race circuit in the world. High-speed work was also carried out at the Nardo bowl in southern Italy, where the Discovery 3 test vehicles circulated continuously for 20 hours a day at, or near, maximum speed. The Nardo test lasted for 12 weeks, and 31,000 miles of maximum speed driving was undertaken. "We were after superb high-speed stability and quietness, and faultless reliability when running continually at these high speeds," says Haywood.
Further high-speed testing was done at the Millbrook proving ground in Bedfordshire, England. Millbrook’s tough and varied handling circuits were also used to tune on-road composure. The MIRA test track, in Warwickshire, England, was used for similar test programmes, including ride-and-handling evaluation.
Additional dynamic tests were carried out at Ford’s superbly equipped Lommel engineering facility in Belgium – which offers a high-speed bowl, race-circuit style test track, and rough on-road conditions such as notorious Belgian pavé.
City driving will naturally form a large part of the real-world use of the Discovery 3. Tokyo, notorious for traffic, humidity and pollution, was used to test the vehicle’s ability in stop-start traffic and the efficacy of the air conditioning system. Traffic testing was also done in oven-hot Las Vegas, high-altitude Denver and in New York, where radio reception and navigation were also tested among the giant man-made canyons.
"Many miles were racked up in the United States," says Haywood. "We tested in cities, in the desert areas of south-western USA – including Death Valley’s extreme heat – and in mountainous Colorado. The USA offers varied testing conditions, and also help to satisfy engineers that the vehicle will operate well in what is likely to be the biggest market."
The new Land Rover Discovery 3 will inevitably end up a favorite of those who tow boats, caravans and horseboxes. Therefore much testing was carried out to prove the vehicle’s ability with a hefty trailer. One of the favorite trailer-test locations was Austria, where vehicles dashed up and down mountain passes, towing 3.5 tone trailers – the maximum weight permitted.
"There has never been a Land Rover more thoroughly tested than this one," says Haywood. "It’s unlikely that any vehicle anywhere has had to prove itself quite so comprehensively, as master of wading rivers, climbing sand dunes and crossing frozen lakes, yet able to charge around race circuits and high-speed test tracks. It has been an amazing programme, designed to test an amazing vehicle."
LABORATORY TESTING
The Discovery 3 was developed at Land Rover’s renowned research and development centre in Gaydon, Warwickshire, UK, which hosts some of the most advanced automotive testing laboratories in the world. Simulated cold weather testing, noise testing, suspension testing, and all manner of durability tests were performed in the many laboratories. Gaydon’s own punishing off-road test circuit and handling circuit were also extensively used.
Written By admin on 23/6/2004
AL-Kadi Landrover Center
Land Rover LR3 Pricing Announced
IRVINE, CA – Land Rover North America today announced U.S. pricing for its all-new SUV, the LR3. The manufacturer's suggested retail price for the SE model will be $44,995, while the HSE model will retail for $49,995. All models will feature Land Rover's innovative Terrain Response™ technology, a powerful 300 hp V8 engine and the Range Rover-inspired, four-corner, cross-linked air suspension, solidifying LR3's outstanding on and-off-road performance.
"The all-new LR3 is the most technologically advanced, boldest, Land Rover ever launched in the history of the company," said Richard Beattie, executive vice president, Land Rover North America. "This premium SUV, with its exceptional versatility and capability, is an excellent value considering the amount of feature, content and innovation Land Rover is bringing to the market."
Available in SE and HSE derivatives, LR3 offers the advantages of a powerful and responsive 300 hp 4.4-liter V8 engine, mated to a six-speed electronic automatic transmission. This transmission is intelligent—adapting its shift patterns to driving style and road conditions—and equipped with Command Shift™, allowing the driver full control over gear changes. Special consideration has been given to ensure the powertrain meets Land Rover's exacting standards for on-and off-road capability.
LR3 sets an impressive benchmark for future Land Rover products with its new platform architecture and numerous technological advancements. The new, Land Rover-developed, Integrated Body-frame™ architecture provides a stable foundation for refined on-road performance, while maintaining the off-road qualities essential to every Land Rover vehicle. Careful design and packaging has kept the overall height of the vehicle down, and has positioned the bulk of the vehicle’s mass as low as possible, further adding to the outstanding on-road dynamics.
LR3's all-new Terrain Response™ system is the latest development in four-wheel drive technology. By optimizing the vehicle's sophisticated systems, Terrain Response™ allows the driver to choose from a variety of terrain settings, thus providing flexible and automatic control of the vehicle in all conditions, both on-and off-road. Not only does this help ensure that operation on a range of surfaces is safe and pleasurable, but it minimizes any environmental impact of off-pavement driving.
The electronically-controlled air suspension system provides increased versatility and comfort. With automatic load-leveling and multiple modes (access, standard and off-road) the suspension allows for a softer spring setting in normal driving conditions, and versatility in others. The Range Rover-inspired cross-linking air springs allow for outstanding off-road performance by maximizing ground contact.
The interior package is among the most versatile and accommodating in its class. The cabin of the LR3 is designed to allow maximum comfort for all passengers- even in the third row. When equipped, the third row of seats is capable of accommodating two 95th percentile adults. In addition, the alpine roof—a driver's sunroof and fixed glass over rows two and three—adds to the feeling of spaciousness throughout the interior.
LR3 is available in eight standard colors: Chawton White, Bonatti Grey, Alveston Red, Java Black, Adriatic Blue, Zambezi Silver, Maya Gold and Tonga Green. All colors currently exist in the Land Rover color palate except for Tonga Green, which has been introduced for the 2005 LR3.
All LR3 models come highly equipped with a list of desirable features and innovative technologies. In addition to the base level of content, the HSE adds a touch-screen, voice-activated navigation system, 600-watt audio system, 19"alloy wheels, Bi-Xenon headlamps and memory seats. Full details of trim specifications will be released closer to launch. Sales for LR3 will commence this fall.
**prices noted include destination and delivery charges.
Sounds pretty cool. I might even consider buying one after about three years when it has lost 65% of it's value. Then it might actually be worth buying a Land Rover and dealing with its' issues. It is a real shame that they can't make their reliability better than dreadful.
Ford has done a decent job improving quality on their luxo brandnames. I am sure that the new Land Rovers will have decent quality/reliability...however, i would not be caught dead in the 1st year model.:(
What i worry about is the new "Terrain Response" 4wd system, which THINKS for you in off-roading...it literally takes control away from you. It's probably good for the beginners. However, for the more seasoned off-roader, that's not fun. This is a mistake in my opinion.
Also, for Land Rover, who competes with higher priced vehicles, the new models should have locker as an option...see Touareg and Hummer H2.
Since they raised the base price so much do you think they are making room for a new model in between the LR3 and the Freelander?
Well, the only other new model that i have heard about is the RANGE STORMER, which slots between Range Rover and LR3 (i think)...and is the "sport" model. I think that the next Freelander will go up in price.
Isn't the Freelander a little pricey at present? I'm not sure that would be a good move.
BRING BACK THE DEFENDER!
I remember shopping for one of these and I didn't want to spend the 33K back then. I wish I had, I could have beat on that thing for 10 years and still sell it for a high percentage of its' original cost. That was one LR that had good resale value, actually it is exceptional.
Oh yeah, i forgot...LR is planning on bringing back the Defender in 2006-2007. The BIG question...which platform is it going to be based on??
Link:
TheCarConnection Preview of LR3
2005 Land Rover LR3
Disco is dead in America – but not its spirit.
by Paul A. Eisenstein (2004-09-13)
Ominous storm clouds hang in the sky above. But turn to the west, and a rainbow has risen off the edge of the horizon. If you don't like the weather in northern Scotland, just wait fifteen minutes. It's bound to change. And it seems like the same thing applies to the terrain. One minute, you're surrounded by boggy marsh, another you're at the top of a barren, windswept hilltop.
This is a harsh and rugged place, and certainly not your typical tourist destination. On the other hand, it's a perfect setting for the debut of Land Rover's new LR3, the long-awaited replacement for the British marque's equally harsh-yet-rugged Discovery sport-utility vehicle.
At first glance, you might mistake the new ute for the top-of-the-line Range Rover, particularly the front end, with its crossbar grille and jewel-like headlamps. Such similarities are purely intentional. The design of the new LR3 is more elegant, refined and upmarket than the ungainly Disco, which was a clear case of function over form.
Where the Range Rover was the work of BMW, which briefly owned the British manufacturer, the LR3 is the product of Ford Motor Co. Ford purchased Land Rover for $2.9 billion in March of 2000, and has invested plenty more since then in its effort to transform the long-struggling subsidiary into a profitable operation.
Ford's touch has been reasonably deft and largely invisible. At one point, it was debated whether to make the Discovery replacement share platforms with the popular Ford Explorer. From a balance-sheet perspective, a reasonable case could have been made for such a move. It certainly would have saved a lot of money, but it would have cost the British maker a chunk of its soul, and in the end, common sense prevailed.
About the only apparent case of so-called "badge engineering" can be found under the hood, the U.S. version of the LR3 powered by a 4.4-liter V-8. With 300 horsepower, the Jaguar-derived engine is acceptably quick on the highway, despite the heft of the new Discovery turning in 0-60 times of 8.0 seconds. And with 315 pound-feet of torque, it has plenty of towing power - and enough torque to haul its way out of even the most sodden Scottish bog.
Workhorse still
The Discovery was the workhorse of the Land Rover fleet, and that's not about to change with the debut of the LR3, as we discovered during three days, and several hundred miles, of driving the high roads and low roads at the northern tip of the British Isles. The trip revealed some breathtaking scenery, but also introduced us to some off-road challenges that repeatedly had us holding our breath.
Yet confidence is something the new LR3 quickly inspires. And one reason is all the electronic hardware built into the new SUV. "This is the most advanced vehicle we've ever produced at Land Rover," boasts Pete Rickings, one of the project's development managers.
There are such niceties as Hill Descent Control, a now-familiar system to Land Rover aficionados that permits you to nose your way down even the steepest knoll at a safe speed, without having to ride your brakes and pray. But nothing justifies Rickings' claim more than a sophisticated new feature that Land Rover has christened Terrain Response. By simply rotating a chunky knob on the center console the driver instantly sets the LR3 up for a wide range of off-road driving conditions, from "Mud and Ruts," to "Sand and Dunes." Each of the five modes optimizes the various electro-mechanical controls built into the new SUV, including the air suspension, differential, brakes, and chassis controls. Terrain Response even adjusts throttle response and shifts, something particularly useful when you're trying to feather your way across a jagged boulder.
With the ability to ford a full 27 inches of water and nose down a nearly vertical hillside, it's hard to imagine anything more adept off-road.
Road-ready?
Yet in today's SUV market, does that really matter? A study by the California market research firm, Strategic Vision, suggests that as many as 40 percent of all Land Rover owners will hit the trail at some point or another. But let's face it, bog crawling and hill climbing are the exceptions to the rule. These days, even the most rugged sport-ute is more likely to see duty on a suburban superhighway.
There, the new LR3 holds its own. The ride is acceptably smooth for a truck, which Land Rover credits to LR3's Integrated Body-Frame structure. The concept blends attributes of classic ladder-frame and car-like unibody construction. An added advantage is that the LR3 is "friendlier" in crashes to any car it might strike.
Overall, this SUV is responsive, with reasonably quick steering and a solid, on-center feel. Unlike the old Disco, you don't have to manhandle the new ute to keep it pointed where you want. You'll feel its mass in a hard corner, and LR3 doesn't have the sort of nimbleness of some of the new car-based crossovers, such as Cadillac's SRX, but for those who desire the added off-road capabilities, it's not an excessive tradeoff.
The overall refinement level is significant, both in terms of road manners and appearance. As with the exterior, the cabin bears more than a passing resemblance to the big Range Rover, though there's lots of grey plastic where the flagship ute boasts wood and chrome. Nonetheless, it's an acceptably attractive cockpit, with controls and gauges in an even more ergonomic arrangement than the Range Rover. And there are plenty of cupholders, for American owners.
There's also a lot of room, with seven-passenger seating available. And unlike many of the current crop of three-row SUVs, those dispatched to the back won't be cursing at you for their misery. There's a real back row here, and even some room left over for luggage.
The oversize windows in the rear quarter panels, matched with a sunroof and dual moonroofs, provide a great sense of openness, also much appreciated by those in back. And the offset design of the back hatch makes it especially easy to stow cargo, especially if it's something light you want to toss in.
All this is, of course, probably should be expected from any vehicle pushing into the mid-$40,000 range, once you get it out of the showroom. The original plan, Land Rover insiders concede, was to bring a base LR3 into the U.S. for just under $40,000. Alas, with the fall in value of the American greenback, that simply was not to be.
The higher price point certainly will have an impact on sales, and that's unfortunate, for those who are drawn to this sort of full-range sport-utility vehicle will find that this is perhaps the best product ever to wear the Land Rover badge. Disco may be dead, but the LR3 is making some great music.
Pics from review above
Land Rover LR3
Roaming Scotland in the sensational Discovery replacement.
By Jim Hall
Like the song says, it really is “hip to be square.”
In contemporary automotive design circles, the cube is cool. First, there was the new Hummer H2, big, rugged and square. Then came Scion’s xB, taking boxiness to a whole new level of slab-sidedness. And now, enter the all-new Land Rover LR3, perhaps the sexiest — no, make that the most foxy boxy — of them all.
But there is a lot more to this stunning new Land Rover Discovery replacement than just looks alone. The new LR3 boasts an excellent engine in Jaguar’s latest 8-cylinder, the 4.4-liter AJV8. Retuned for off-road duty (85 percent of peak torque is available from 1500 rpm, the accessory belt is designed to operate underwater, engines are tested on a dyno that tilts up and down 45 degrees, and the LR3 can drive through water deeper than 2 feet) this 300-bhp, 24-valve engine features double overhead cams that are chain-driven rather than belt for durability, forged steel connecting rods, weighs in at a light 440 lb. and is the most powerful engine in Land Rover’s history. Its compact nature also helped the engineers to configure an increased approach angle when tackling the steep stuff off-road.
The same ZF 6-speed automatic gearbox with Command Shift manual shifting capability as found in the V-8-powered Jaguar sedans sees further development for use in the LR3 with an all-new torque converter developed specifically for SUV application. The transmission is also lightened by 44 lb. while simultaneously increasing overall stiffness. In highway driving, the full-time all-wheel-drive system’s torque split is 50/50 front and rear. Towing capacity is rated at 7,000 lb. and the EPA figures are 14 mpg city and 18 highway.
The LR3 comes standard with active center and rear differentials and an air suspension system that has all of the functionality of the top-of-the-line Range Rover, including the ability to raise the ride height by 2 in. for off-roading and lower it by 2 in. to facilitate easier cargo loading. The suspension design in the LR3 was inspired by the independent suspension found in top-level Jaguars with the goal of making the SUV’s ride quality on a par with the Lexus RX 330. Mission accomplished: on-road, the LR3’s ride is supple yet sturdy — not unlike the ride characteristics of today’s top German luxury sedans and a far cry from the Discovery’s wallowy nature.
Aiding the LR3 in its quest to venture into parts and terrain unknown is Land Rover’s innovative new Terrain Response system, a standard feature on all LR3s. To engage the system, simply turn the knob located on the center console to one of five settings: the first for general on-road/off-road conditions, the second is for grass/gravel/sand, the third for mud and ruts, the fourth is for sand dunes and beaches, and the last for rock crawl mode. By measuring slip and steering angle (and a multitude of other parameters), Terrain Response adjusts and optimizes the traction, ABS, differentials, throttle, gear change points, hill descent and air suspension ride height to get you in, through and out of the muckiest of muck. This is one impressive traction system, having been tested to deliver optimized results on over 50 different types of surfaces. Perhaps the most impressive display of the system was when we watched the LR3 drive on a small section of test track at the Land Rover factory in England on a surface that consisted of nothing but ball bearings…try and walk across something like that!
The design and engineering present in the LR3’s chassis are light-years ahead of the last-generation vehicle as well. The body is actually wrapped around the chassis rather than merely resting atop it, making for excellent rigidity, as the driver really gets a great sense of the car’s sturdy feel when behind the wheel. The frame rails are hydroformed for optimal strength and tolerances, the hood and upper and lower tailgate are composed of aluminum to lessen weight and the driveshaft passes through the frame, allowing for a flat interior floor.
And speaking of the interior, the LR3 sports a slew of luxury and technical features in its cabin. Though not as posh as the Range Rover, the interior is stylish but businesslike — more rugged chic, less bling. Power front seats, leather, full climate control and a 300-watt, 9-speaker AM/FM/6-disc CD changer by Harman/Kardon come standard. Seating for five is the standard configuration with a seven-seat layout available as an option, the latter an excellent design as it allows for adults — not merely children — to enter and exit quite easily the rear bench row seating, which offers surprisingly decent accommodations. And when not in use, both rows of rear seats (in 7-passenger form) fold flat.
The entry-level SE model is priced at a very reasonable $44,995. The top-flight HSE edition sells for $49,995 and includes a voice-activated on/off-road DVD-based navigation system, 4x4 driver information center, bixenon headlights, foglights, rain-sensing wipers, headlight power washers, HomeLink garage opener and rear park assist.
The Land Rover folks picked an ideal setting for the media to evaluate their Disco replacement: the uppermost section of Scotland. With its beautiful coastline, rugged beaches, wide-open plains and soft, car-gobbling peat, we were able to sample a variety of terrain that would be a test for any of the top dirt-devouring trucks or SUVs. With Land Rover’s new LR3, and its Terrain Response technology, it was all a piece of cake.
Now, eating haggis, that was anything but a piece of cake!
Philthyphilthy
