2005 Rear window issues and more
space_coyote
Hey,
I just got a new to me 2005 4Runner which I'm pretty excited about but I'm starting to find issues that weren't apparent before. Ive gotten past the "oh shit, buyers remorse" stage, and I'm ready to get this to a reliable driver. Hope you guys can't point me in the right direction.
I went to put the rear window (the tailgate one? back? rear?) and it went down more or less sideways and refused to come back up. Pulled the interior panel and found lots of rusty parts (I'll address that in the spring.). It seems that passenger side part that connects to the window and rides in the rail totally disintegrated, but the cables are all still connected.
[edit: looks like I might need the entire "regulator" [ 4 ] BODY HARDWARE / LIFT GATE / GLASS & HARDWARE / Regulator Part Number: 6980735020 if the parts aren't available individually]
I managed to shove the window back up while someone else was hitting the switch. The rear defroster and rear wipers also don't work, but from what I've read, this is probably the car thinking that the window is down. I can't reliably do a full down-back up cycle with only half the window lifter mechanism attached. Any way to fool it in the meantime?
I'm not sure where to look for part names and numbers. I come from the Subaru world where I knew where to find stuff, but in reality, the best place to start is forums. I'll be here lots!
The other issue is that my "you're skidding," "vsc" and one other adjacent light are all on at once. My mechanic said that something might have gotten wet while he was spraying off the frame and undercarriage during inspection. It did turn off for one out of the last 10 or so driving cycles (start - drive - off). Any ideas there? I like Christmas trees, but not on my dashboard.
Third thing, I noticed in the stickies, that there's a link to download a zip of the 2006 FSM. I've tried on two computers and it tells me that the zip file is invalid (but still large enough to have downloaded completely). Can someone verify for me that I'm not doing it wrong?
Thanks! (and I'll take pics and whatnot when it's nice out). But, it's gray sr5 and 100% stock.
I would use this website and see if you can find the parts you need: Toyota Parts - Shop OEM Toyota Parts Online at Village Toyota
As for the Traction and VSC lamps being on, you'll need an ABS capable scantool to pull the DTCs so we have an idea what we're looking at. Usually its something as simple as a the ZPC (Zero Point Calibration) needing to be reset. But its not as common an issue on '05+ 4Runners as it is on the '03 & '04 which are very sensitive to low voltage and lose/curropt the Zero Value easily.
And for the rear window, it has to be FULLY up for the def./wiper to work. Maybe try with the button to ensure it's fully up. Other issue is the sensor may be tied into the part that failed, so..... maybe out of luck until it's replaced.
Is the check engine light on also? If so, it could be a multitude of issues (from as simple as a gas cap failure). As BlackWorksInc said, you need to get the codes (Welcome aboard - as you'll probably see, BlackWorksInc knows his stuff).
Thanks for the help guys. I don't think my scan tool is good enough for that, so I'll try to pull the codes tomorrow. There's also a standard CEL (which I believe is catalytic converter) that I'll read tomorrow also.
Hopefully I can stick around here long enough that I can start helping too.
The regular CEL was a P0606
P0606 Toyota - ECM Processor Error
Possible causes
- Faulty Engine Control Module (ECM)
- Engine Control Module (ECM) Harness power supply circuit is open or shorted
- Engine Control Module (ECM) Programming
which sounds like just about the worst thing imaginable. I cleared it with my 20$ code reader (which also seemed to clear the VSC lights) but I haven't driven it yet. It seems to drive just fine, but please tell me this thing isn't DOA.
Hopefully you'll be fine. Pretty much ANYTHING that trips the CEL will also trip the VSC & related lights.
