xcmountain80
It is the damndest thing. Parked it last weekend, then it would t start, turns over with plenty of power but won’t start. I troubleshot it down to what I believe is a faulty fuel pump given the mileage. Nope that wasn’t it. Have checked resistance in the camshaft position sensor, multiple relays, but could be doing that incorrectly as I don’t know which pin activated the gate on the relay. MAF was a bust as I don’t know which pin configuration will give me a reading. Spark plugs need to be replaced but should not be the root issue. Also spark plugs were not wet with fuel when I checked following a crank attempt, which tells me there I may be restricting the flow of fuel. I have no check engine light and no codes. I have eliminated the possibility of the built in security device (chipped keys).
