2005 T4R Wiper switch relay replacement
how do you remove the switch from the column
Hi Dave,
Not sure if you found your answer or not...but, I can't really remember myself.
After doing a search, I came up with a post from someone else, as follows...
"You just have to remove the covers off the column behind the steering wheel. Turn the wheel side to side and youll see two screws. Remove those and i think there may be another one underneath the column to remove. Then the covers just pop off. Youll see youre switch components and it should be just a couple screws holding the switch on."
Hope this helps! Good Luck!!
seltzernator
