2006 head unit jbl
If I am not mistaken, the 2005 unit is digital (whereas the 04 and 03 units were analog).
I'm pretty sure all the JBL systems were digital. I think that was the "up sell" when going JBL, along with the 4 extra speakers. I had the 2004 single disc JBL and now have a 2005 6 Disc JBL and they both sound the same.
sharp4runr,
You were able to drop in an 05 JBL to replace your 04 JBL without having to switch out the AMP? I am just wandering ... since I am selling my 05 I would like to know whether to tell people with 03's and 04's whether or not it will work with their system...
BTW : My assumption that the 05's are digital and the 03's and '4s are analog comes from the fact that oemvalue.com sells two different packages for their nav system. The first package is for "applications with the analog JBL sound system" and the second package is for "applications with the digital JBL surround sound system". Someone has previously told me that the 03's and 04's required package one and the 05's and 06's required package two --- thus leading me to believe that only the 05's and 06's were digital.
Yup, just swapped out my JBL unit with the 2005 one. I didn't have to fiddle with the external at all. You may just want to have a disclaimer saying they should check to make sure this will fit their application. I documented my swap on the board (if you're interested, just do a search) and it did involve swapping some other componenets but not the AMP.
Hmm, that's interesting how OEMValue separated the years that way. Well I guess I have the Digital JBL now :)
I tried to buy a 2006 jbl anit from someone I think they said the harness was different or the amp was different.
Different compared to what? The 2006 JBL Amp and Headunit have the exact same wiring as the 2005 models. And --- I am being told that the wiring on the 2005 is the same as the 04's and '03s .... So -- transitive property tells me that all the wiring is the same.
Yeah -- I am unaware of any harness change in late 05 .... The 06 worked fine in my 05.
