2006 Toyota 4 Runner Headlight issue
skippyams
Needing help with the following issue.
Headlight will go out and when I turn the bulb holder to remove it from the shell it comes back on. It may then work for a day or two but then does it again. I have put dielectric grease on the connections to try to prevent any corrosion (not that I have seen any at this point). Today I didn't remove the bulb holder just pushed on the bottom side of the connector and the bulb came back on.
I have also changed bulbs, used several brands but all end up in the same boat after a few days.
Any help would be great
Probably a wiring issue along the headlight socket connector. They are replaceable, can be had for a few bucks @ a local auto parts store. A few electrical hand tools and you should be good to go.
utkrstam
